![]() | Home > Puma (Tdci) > Alarm 10As Puma 2.4 |
That sounds like the action for when you've left a door open. The horn will sound twice and not activate the alarm.
If you open all the doors and then close them again does the interior light stay on or anything? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6714 ![]() ![]() ![]() |
Agree with the above, it "hoots" and doesn't flash the lights when locked if it thinks a door is open.
lesende Member Since: 17 May 2018 Location: Galicia Posts: 9 ![]() ![]() ![]() |
thanks cupboard and Martin, the light stays on for 15 or 20 seconds and then it goes off if I connect the alarm it sounds twice and if I open a door the alarm sounds, that is to say if it connects the alarm and with the engine turned on the interior lights go off much faster
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The bonnet switch will also have the same effect I think. As the alarm will think the bonnet is open.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Have you tried a AS10 re-set? Sit in the car, arm, unlock, open the door and close. Merlin.
Solved. the bonnet switch failed. Does anyone know the reference to order the piece? and thank you all for your help
AMR2022. Well done for finding the problem
Thanks to all for the help
