Home > Puma (Tdci) > Alarm 10As Puma 2.4
lesende
Spain 2008 Defender 110 Puma 2.4 SW Alaska White
Alarm 10As Puma 2.4
Hello everyone, I have a problem with the alarm module of my defender Puma 2.4, every time I connect the alarm the car gives two horn sounds and it is not comfortable for my neighbors when I arrive very late at night. I tried to change it with the nanocom but I have not been able, any of you could guide me on how to do it, if possible.
The car sounds twice when the alarm is connected, but it does not turn on the turn signals, however when it is switched off it turns on the turn signals and does not sound.
Thanks for your interest and help
Post #707657 17th May 2018 10:08am
Cupboard
That sounds like the action for when you've left a door open. The horn will sound twice and not activate the alarm.
If you open all the doors and then close them again does the interior light stay on or anything?
Post #707666 17th May 2018 10:28am
Martin
Site Admin
Agree with the above, it "hoots" and doesn't flash the lights when locked if it thinks a door is open.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #707671 17th May 2018 10:39am
lesende
thanks cupboard and Martin, the light stays on for 15 or 20 seconds and then it goes off if I connect the alarm it sounds twice and if I open a door the alarm sounds, that is to say if it connects the alarm and with the engine turned on the interior lights go off much faster
Post #707679 17th May 2018 11:22am
zsd-puma
The bonnet switch will also have the same effect I think. As the alarm will think the bonnet is open.
Post #707719 17th May 2018 3:22pm
Merlin
Have you tried a AS10 re-set? Sit in the car, arm, unlock, open the door and close. Merlin.
Post #707733 17th May 2018 4:43pm
lesende
Solved. the bonnet switch failed. Does anyone know the reference to order the piece? and thank you all for your help
Post #707767 17th May 2018 7:45pm
Martin
Site Admin
AMR2022. Well done for finding the problem Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #707813 17th May 2018 10:08pm
lesende
Thanks to all for the help
Post #707854 18th May 2018 8:42am
