![]() | Home > Td5 > Fuel leak :-( |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello excossack
Yes. Probably not the Tank but the Fuel Breather Pipe attached here... a Search on D2N will show this particular LR feature... Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Thanks, I will take a look. I do have a spare one, as I had spotted the end of the pipe that goes to the filler neck was showing signs of it splitting.
When I had a look the top of the tanks was certainly wet but could not locate exactly where (unless fuel breather being split is squirting the fuel out and then running down from the top of the tank? There is wetness on the passenger side of the tank guard. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
This is all it took on mine...
Click image to enlarge apparently a 110 is easier to get at than the 90 so good luck... https://www.defender2.net/forum/topic83242.html |
Cheers. I had a quick look this morning and now it raining.
Decided to send the 110 into the garage as I am lacking in time this week, but I will be sure to mention the possible split hose to the mechanic. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 241
Mine did the same was both breather hoses:
Is that the breather to the little egg shaped thing in the passenger rear wheel arch?
It must be age thing, we are go wrinkly in the end... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
That’s the one
So...Possibly 2 split hoses then
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2529
my 2008 on 180k has started doing it 3 weeks ago, haven't had time to get it in, only does it when its full but at 6-700 miles a week it doesn't stay full for long
2015 Discovery 4.5 Black pack Firenze red XS |
Mine is just under half full and dripping well but only with fuel pump going. So what it will be like driving, no idea! 1999 Defender TD5 110
Mine only did it with a fairly full tank as well, I assumed it was when sloshing about and exiting through the breathers.
When fuel pump running would probably indicate one of the fuel pump lines instead? |
I was leaning towards a return hose as it take 10/20 seconds before fuel starts leaking 1999 Defender TD5 110
110 is in the garage having its rear end fiddled with. Last seen the fuel was being drained. 1999 Defender TD5 110
All fixed. Turned out to be a fuel hose at the top of the tank. As you look at the fuel pump from the rear, it was the pipe nearest to the drivers side. (Low pressure return line?) 1999 Defender TD5 110
