![]() | Home > Maintenance & Modifications > Advice wanted: Twin battery installation |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
John, no problem as it happened I am down at the lockup today with the new usused one. Photos (in order: length, width, deeper end, shallow end):
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
You can fit two normal sized 019 batteries in the standard box. A 019 is the standard size fitted to a Defender.
I've leveled the bottom off using some bits of 1/2" ply in the stepped lower bit and used some M8 threaded rod atached (somehow, I can't remember how) to a stock battery mount to clamp them down. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
Thanks Steve. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 241 ![]() ![]() |
Hey Steve,
Thanks for all the great info - one more what’s the conduit you have used? Thanks, Tom |
