Home > Puma (Tdci) > Replacing washer jet: removing dash
Leaky 110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Hi folks
I know there’s a few threads on washer jet upgrades, but all I really want to do is replace my standard one which snapped during the recent cold weather and is now held on with sealing mastic 😂
To get access to the nut from the dash side do I need to remove the centre console section and radio, or does the instrument binnacle need to come off too?
I can’t quite make it out from the workshop manual, I’m sure lots of people will have fixed this!
Post #703351 26th Apr 2018 6:27pm
lohr500
I'm sure I read a previous post on this (and made a mental note to self) saying that the jet could be replaced just by removing the centre console and radio. I could clearly see the jet nozzle fixing on mine when I had the centre console out a few months ago to sort out the radio. But as I had no need to tinker with the washer jet, I can't confirm if it can be done.
If the instrument binnacle does need to come out as well, then that is a simple job and can be done with the standard steering wheel in place.
Good luck.
Post #703368 26th Apr 2018 7:31pm
Thon
http://www.defender2.net/forum/topic50670-15.html
2nd page of this post shows how to do it - I saved it because I needed to do the same, but mine leaks so much the dash has had to come out this week for major remedial action.
Post #703370 26th Apr 2018 7:36pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
if you have small hands you can do it through the ash tray, that's how I replaced mine with on wiper jets and I don't have small hands Laughing
Post #703372 26th Apr 2018 7:40pm
No ash tray on a Puma.
Yes it can be done if you just remove the centre panel, I have done it twice in this way now.
Post #703384 26th Apr 2018 8:33pm
Leaky 110
Good effort that chap! I’ve read through loads of these threads and couldn’t find a nugget of wisdom like that post. Makes it look really easy now. I’ll maybe take some pics and upload them.
Thanks folks 👍
Post #703388 26th Apr 2018 8:45pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Leaky, make sure you really need to do this. The washer jet comes in two parts, the threaded part attached to the bulkhead and the actual jets themselves which just push on (very firmly, or a tap with a rubber hammer) and clip into place .
If you're lucky you may just be able to push on the new jet part? 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #703432 26th Apr 2018 10:13pm
Maxxed_Ross
Sorry just noticed this was in the TDCI section not the TD5 one... normally my "new post" button filters it out Confused
Post #703449 26th Apr 2018 11:17pm
rossy
Hi Leaky
you could save yourself a lot of time by doing the following - similar to Natlas' post above
- Get a washer jet from Paddock spares -they're about a fiver
- while holding the thread and nut end with a pliers wiggle the jet moulding gently until it pops off the pipe
- apply some bog standard superglue to the the pipe that is sticking out of your bulk head and immediately push the new washer moulding on using as much pressure as you can.
There's a thread on this somewhere here as its a common issue. I bought 2 of them just in case and two years later I'm still on the first Paddocks cheapie ! Its a pig to get the washer jet aim just right but once set it stays. Job done Thumbs Up
Post #703810 28th Apr 2018 5:05pm
zsd-puma
I tried to pull my old one off, it just snapped off the thread.
It only takes about 10 min to pop out the radio and centre part of the dash, along with the small metal radio support behind it.
Post #703848 28th Apr 2018 7:17pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Do a google search for part number DNJ500270 - the front jet part is available all by itself.
It'll save you a whole load of grief...
https://www.landroverworkshop.com/parts/DNJ500270 Dave
Green Goddess - 1998 Defender 110 300tdi
Post #703857 28th Apr 2018 7:49pm
Last time I checked the front part of the jet was very substantially more expensive than the complete jet, leading me to conclude that you're paying for a complete jet and someone's time to pull it apart and repackage half of it. It makes no sense!
Post #703878 28th Apr 2018 10:05pm
nosnibod
Until you try and get it apart yourself and then wreck it... and it’s far easier than opening up the dash. I agree it’s wxpensive though... Dave
Post #703887 28th Apr 2018 11:05pm
zsd-puma
Surely the same applies to the blocked one already fitted to your car that you're going to replace.
You could buy the 'repair' part, snap the threaded part on the car, then have to go back and buy the complete unit anyway.
Unless you've gone for a big Double din install, it's no effort at all to pop the centre dash fascia out.
Post #703889 28th Apr 2018 11:29pm
nosnibod
It's just an option available to the OP who said that the jet popped apart in the cold weather meaning that it probably froze - that seems like quite a common failure mode.
Horses for courses... Dave
Post #703909 29th Apr 2018 8:16am
