Home > Technical > Engine temp (Std or tweaked)
MK
For those who can read from a nanocom-scangauge etc what sort of coolant temp you get at highway speed? Puma 110" SW
Post #70013 7th May 2011 11:14am
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Re: Engine temp
90 degree. Thumbs Up
Ciao Vinicio https://google.com/+VinicioSelleri
Post #70019 7th May 2011 1:57pm
Lorryman100
Mine too, 90 degrees centigrade. Thumbs Up
Post #70081 7th May 2011 8:37pm
vinsell
Re: Engine temp
Ciao Vinicio
More info:
120 km/h 94 degree with outside temp at 25 degree. it varies from 88 to 96.
Post #70197 8th May 2011 8:30pm
ickle
std 110 csw Puma, 26 degrees ambient, 86 - 88 degrees driving 100 - 110 kph back up through France
Post #70201 8th May 2011 8:42pm
TJ101
Just back from Croatia, 3500 miles trip,, (both their and back in more or less one hit) !!!
Quite regularly, the scangauge recorded 100 deg as it max,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #70207 8th May 2011 9:27pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
89C at 80mph on trip to Exeter - 120m on M4/M5- in 6th gear all the time on the motorway. Air-Con ON. Smile
Post #70212 8th May 2011 9:50pm
Naks
Fully loaded to 2500kg, ambient temp 34C, driving at 100kmh (GPS) all day: 92C --
Post #70992 15th May 2011 10:16am
Alexke
Belgium
Re: Engine temp (Std or tweaked)
Are you sure its measuring coolant temp? The dial and Scangauge temp are from the Cylinder Head Temperature sensor! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #76004 15th Jun 2011 2:13pm
MK
Not sure, but I read coolant temp in my BBox, So I guess it is a fluid Puma 110" SW
Post #76033 15th Jun 2011 4:48pm
Lorryman100
Yes it is the temp of the cylinder head and not the coolant. Thumbs Up
Post #76145 15th Jun 2011 11:46pm
Tjhappel
United States 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
I'm getting temps while towing in 30-35 c weather of 95 to 105... I was worried when it hit 103, then 104 then 105... All seemed ok with it, car didn't go into limp mode or anything else. Can anyone confirm if I should be troubled with that temp?
Post #169033 18th Sep 2012 12:46am
my ultraguage shows 80-86 on a A-road run
Post #169036 18th Sep 2012 6:42am
WelshGas
During a 4hr trip from Norfolk to South Wales, Motorway and fast A roads, with +70mph on Motorway and 40 to 60 on A roads, Scanguage showed 89 to 91 C the whole way. AC on all the time. Has been the same since new. I use a Radiator Muff during the winter to speed up Warm Up as I still have AC on for it's drying/de-misting abilities. Temperature still stable 89 to 91 C. When idling at rest the Scanguage shows a Temp drop, slowly over time, as the AC fan is working and the internal heater matrix is still operational. Turn Off AC and internal Heater and temperature drops very very slowly at idle if cold outside. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #169038 18th Sep 2012 7:01am
ajps72
2001 Defender 110 Td5 SW Chawton White
Hello MK, in my TD5 the Nanocom reads 80 in traffic and in the city, on highways it goes up to 93C, BUT when climbing at highway speeds it will go to 105C without the temp gauge moving from the middle.
I normally end up going at 60km/hr to keep the temp down. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #169277 19th Sep 2012 1:43pm
