![]() | Home > Technical > Engine temp (Std or tweaked) |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
90 degree. ![]() Ciao Vinicio https://google.com/+VinicioSelleri |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Mine too, 90 degrees centigrade.
More info: 120 km/h 94 degree with outside temp at 25 degree. it varies from 88 to 96. Ciao Vinicio https://google.com/+VinicioSelleri |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1861 ![]() ![]() ![]() |
std 110 csw Puma, 26 degrees ambient, 86 - 88 degrees driving 100 - 110 kph back up through France
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Just back from Croatia, 3500 miles trip,, (both their and back in more or less one hit) !!!
Quite regularly, the scangauge recorded 100 deg as it max,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
89C at 80mph on trip to Exeter - 120m on M4/M5- in 6th gear all the time on the motorway. Air-Con ON.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2682 ![]() ![]() ![]() |
Fully loaded to 2500kg, ambient temp 34C, driving at 100kmh (GPS) all day: 92C --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
Are you sure its measuring coolant temp? The dial and Scangauge temp are from the Cylinder Head Temperature sensor! Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
Not sure, but I read coolant temp in my BBox, So I guess it is a fluid Puma 110" SW
Yes it is the temp of the cylinder head and not the coolant. ![]() |
Tjhappel Member Since: 08 Aug 2012 Location: Southern California Posts: 32 ![]() ![]() ![]() |
I'm getting temps while towing in 30-35 c weather of 95 to 105... I was worried when it hit 103, then 104 then 105... All seemed ok with it, car didn't go into limp mode or anything else. Can anyone confirm if I should be troubled with that temp?
my ultraguage shows 80-86 on a A-road run
During a 4hr trip from Norfolk to South Wales, Motorway and fast A roads, with +70mph on Motorway and 40 to 60 on A roads, Scanguage showed 89 to 91 C the whole way. AC on all the time. Has been the same since new. I use a Radiator Muff during the winter to speed up Warm Up as I still have AC on for it's drying/de-misting abilities. Temperature still stable 89 to 91 C. When idling at rest the Scanguage shows a Temp drop, slowly over time, as the AC fan is working and the internal heater matrix is still operational. Turn Off AC and internal Heater and temperature drops very very slowly at idle if cold outside. LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
Hello MK, in my TD5 the Nanocom reads 80 in traffic and in the city, on highways it goes up to 93C, BUT when climbing at highway speeds it will go to 105C without the temp gauge moving from the middle.
I normally end up going at 60km/hr to keep the temp down. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
