Home > Maintenance & Modifications > 2.4 sump oil leak
2.4 sump oil leak
My 90 over the last few months has developed a leaky sump, nothing much but enough to need to repaired.
Luckily it's not a heavy leak.
I'm pretty sure the sump it's self is fine but the seal is going.
Can anyone confirm if it's a gasket type seal or a wet assembly style sealant?
I'm tending to think the latter.
I've also got a PAS leak on the steering box, guessing that's going to be pretty expensive. Sad ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #697411 31st Mar 2018 11:51am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Jup is expensive Big Cry
I've replaced it before with a LR one. Next time i'am going for another steering box.
Does anybody knows how the bowler (close ratio) steering box holds up? Perhaps an idea for you too? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #697422 31st Mar 2018 12:29pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
https://m.ebay.co.uk/itm/BRAND-NEW-FORD-TR...1971823609
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #697425 31st Mar 2018 1:43pm
ericvv
I once let the dealer replace my sump after the tip of my oil gauge broke off and fell into the sump and just sat there. The old sump itself was perfect, no leak at all, but dealer said to never take off an even perfectly good sump and then put it back just with new sealant. It surely will leak then as the sump metal just will have deformed. So a new sump with new sealant was installed, leakfree to date.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #697438 31st Mar 2018 2:29pm
ian series 1
They are bonded in the same way that the timing cover is fixed,
Timing covers are very tricky to remove without bending,
I always replace them with a new one.
The sumps have a bit more strength to them, as they are not just a flat panel, and do come off if you run a blade around them, as long as the seal breaks evenly, you will be fine.
Replace with a gasket as above or RTV sealer, just give the sump a good clean off to make sure it is still oil tight, and not porous. 80" 80" 86" 88" 90"
Post #697446 31st Mar 2018 3:40pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I seem to remember the early Puma sumps were replaced on a recall due to the propshaft coming into contact with them on full articulation. I didn't bother with my 07 SW as it never went seriously off road.
Post #697471 31st Mar 2018 5:48pm
Thank-you all.
I was wondering regarding the seal type as suggested and I did wonder about the sump deformity due to being removed and re-fitted.
So new sump it is.
I assume the 2.4 Transit sump fits, or is the sump specific to the Defender with the prop articulation issue? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #697476 31st Mar 2018 6:08pm
Correct. My sump was replaced for this reason.
Post #697525 31st Mar 2018 9:16pm
dgardel
Italy
custom90steve wrote:
Thank-you all.
So new sump it is.
No, the Defender sump is different due to the room necessary for the front shaft joint.
No paper seal, only the silicon style sealer and, yes, you need a new sump for the deformation due to being removed and re-fitted Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #697563 1st Apr 2018 12:21am
Looking at getting this today, can anyone confirm the part number as being the up to date version?
The Genuine P/N I have is: LR007598
Obviously doesn't include the other parts except the sump pan it's self.
Thanks Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #700181 11th Apr 2018 1:30pm
ericvv
Just checked my invoices. My sump was replaced half a year ago when dealer had to retrieve the broken off oil gauge tip from the sump. The genuine sump part number still is LR007598. In addition the invoice gives the number for the genuine bonding paste they used for the new sump. That is STC50550.
Post #700201 11th Apr 2018 3:13pm
That’s excellent, thank you Eric.
Much appreciated. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #700205 11th Apr 2018 3:32pm
