|  | Home > Maintenance & Modifications > 2.4 sump oil leak |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | Jup is expensive     I've replaced it before with a LR one. Next time i'am going for another steering box. Does anybody knows how the bowler (close ratio) steering box holds up? Perhaps an idea for you too? a defender from 1984 pretending to be a puma with a touch of Range Rover Last edited by Tdi4 on 31st Mar 2018 12:59pm. Edited 1 time in total | ||
|  31st Mar 2018 11:29am |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127      | https://m.ebay.co.uk/itm/BRAND-NEW-FORD-TR...1971823609
  80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. | ||
|  31st Mar 2018 12:43pm |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817      | I once let the dealer replace my sump after the tip of my oil gauge broke off and fell into the sump and just sat there. The old sump itself was perfect, no leak at all, but dealer said to never take off an even perfectly good sump and then put it back just with new sealant.  It surely will leak then as the sump metal just will have deformed.  So a new sump with new sealant was installed, leakfree to date.
 Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw | ||
|  31st Mar 2018 1:29pm |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127      | They are bonded in the same way that the timing cover is fixed,
 Timing covers are very tricky to remove without bending, I always replace them with a new one. The sumps have a bit more strength to them, as they are not just a flat panel, and do come off if you run a blade around them, as long as the seal breaks evenly, you will be fine. Replace with a gasket as above or RTV sealer, just give the sump a good clean off to make sure it is still oil tight, and not porous. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. | ||
|  31st Mar 2018 2:40pm |
| defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629      | I seem to remember the early Puma sumps were replaced on a recall due to the propshaft coming into contact with them on full articulation. I didn't bother with my 07 SW as it never went seriously off road. | ||
|  31st Mar 2018 4:48pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Thank-you all.
 I was wondering regarding the seal type as suggested and I did wonder about the sump deformity due to being removed and re-fitted. So new sump it is. I assume the 2.4 Transit sump fits, or is the sump specific to the Defender with the prop articulation issue? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ | ||
|  31st Mar 2018 5:08pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      |
 Correct. My sump was replaced for this reason. | ||
|  31st Mar 2018 8:16pm |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    |
 No, the Defender sump is different due to the room necessary for the front shaft joint. No paper seal, only the silicon style sealer and, yes, you need a new sump for the deformation due to being removed and re-fitted Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  31st Mar 2018 11:21pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Looking at getting this today, can anyone confirm the part number as being the up to date version?
 The Genuine P/N I have is: LR007598 Obviously doesn't include the other parts except the sump pan it's self. Thanks  ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ | ||
|  11th Apr 2018 12:30pm |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817      | Just checked my invoices. My sump was replaced half a year ago when dealer had to retrieve the broken off oil gauge tip from the sump.  The genuine sump part number still is LR007598.  In addition the invoice gives the number for the genuine bonding paste they used for the new sump. That is STC50550.
|  11th Apr 2018 2:13pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | That’s excellent, thank you Eric.
 Much appreciated.  ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ | ||
|  11th Apr 2018 2:32pm |
| Posting Rules
