![]() | Home > Maintenance & Modifications > Alpine Window fitting |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
They are really stubborn to fit. I've done a couple of sets now (one was with holes I'd cut myself so was unsure if they were the right size, the other was when I resprayed a roof, so took t he factory ones out and refitted)
Both were just as awkward as each other. I think I just used copious amounts of washing up liquid and brute force. Fortunately the glass is quite tough so I didn't break any. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
Have you tried the well tested method of using string around the seal? If you're unfamiliar with the method then type "Fitting a windscreen with string" into You Tube. Defender 90XS SW
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 179 ![]() ![]() ![]() |
Here’s a few pics of mine going in. The rubber was all perished on the old ones so I pulled them out cleaned it all up and fitted the new ones. It was a bit of a fight but the second side was easier! I used the orange twine you get on crabbing lines as it is thin, string and slippery to pull the rubber over the glass. I also remember the glass looked like it was sitting proud of the roof but with some brute force, I managed to push the glass back into the recess sufficiently. I would also highly recommend the special tool for fitting the infill rubbers and plenty of soapy water.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2002 Defender 110 CSW TD5 |
EuropeDefender Member Since: 02 Apr 2018 Location: Tuscany Posts: 11 ![]() ![]() ![]() |
I replaced my Alpine seals last sunday.
It was a really really complicated job. If I had not disassembled by myself the windows few minutes before, I would have thought that the glasses are wrong with my car. Now reading this thread I discover that there are seals for 4 and 5 mm glasses. May be my new seals were wrong... Si Vis Pacem Para Bellum |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
Anyone cut alpines I to a roof?
