![]() | Home > Maintenance & Modifications > Fitting a new exhaust system on Puma 90 |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
I vote for easy.
Be prepared for Some rusted bolts and nuts. But if you replace the current system you can allways use the grinder |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Easy DIY, refit with new nuts and bolts though!
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
easy, if you have a grinder to hand for just in case they dont come undone - and some glasses! Cheers
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
If you did need a grinder you'd need a larger one too I'd have thought due to disc cutting depth.
A small one would be much more easier to use, but cutting depth wouldn't be right through. Or carefully use a sabre saw, much less sparks etc ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226
All done. I used a jigsaw in the end to cut the back box off, but other than that it was a pretty straight forward job.. Needed to take the rear wheel off the allow the rear bend on the exit pipe through.
| CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1912
Pics
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
I’ll pop some pics on tomorrow or monday... i’m aching so much from fitting it all i had to come straight in and have a warm bath
Suggest a glass of something will also help a lot
