![]() | Home > Maintenance & Modifications > Fitting a new exhaust system on Puma 90 |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
I vote for easy.
Be prepared for Some rusted bolts and nuts. But if you replace the current system you can allways use the grinder ![]() |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2216 ![]() ![]() ![]() |
Easy DIY, refit with new nuts and bolts though!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8293 ![]() ![]() ![]() |
easy, if you have a grinder to hand for just in case they dont come undone - and some glasses! Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20889 ![]() ![]() |
If you did need a grinder you'd need a larger one too I'd have thought due to disc cutting depth.
A small one would be much more easier to use, but cutting depth wouldn't be right through. Or carefully use a sabre saw, much less sparks etc _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
All done. I used a jigsaw in the end to cut the back box off, but other than that it was a pretty straight forward job.. Needed to take the rear wheel off the allow the rear bend on the exit pipe through.
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1891 ![]() ![]() |
Pics
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I’ll pop some pics on tomorrow or monday... i’m aching so much from fitting it all i had to come straight in and have a warm bath
Suggest a glass of something will also help a lot
