Home > Puma (Tdci) > 2.4 PUMA theft risk?
Phil_C
2010 Defender 90 Puma 2.4 HT Galway Green
I have just started bolting all sort of goodies onto by 2010 2.4 and want to make sure I am covering the bases when it comes to security.
If it is parked for any time I am using a Stoplock Pro steering lock that makes it impossible to turn the wheel without opening the door.
Otherwise it only has the Landrover standard alarm and central locking.
But in reality how vulnerable are Puma Defenders to theft without the keys except by trailering away?
Thanks - Phil. 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
2010 TDCi Puma 90 HT - Bulkhead removal kit, Ashcroft front and rear lockers, Andersons front and rear, Warn XD9000i winch, battery split charge system, Patriot full roof rack. OME Suspension.
2013 Freelander II GS - Factory standard
Post #696981 29th Mar 2018 4:45pm
zsd-puma
Very. The ignition switch is from a Morris Marina.
Post #696983 29th Mar 2018 4:48pm
Phil_C
I appreciate the key is not 'good' but I thought they had an immobiliser chip built in as well- is that wrong? 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
Post #696984 29th Mar 2018 4:50pm
They are exceptionally easy to open without the key, once open it is very easy to overcome the factory immobiliser and start the engine. If it has a battery backed sounder it takes a few minutes longer but isn't much harder. Say 10 minutes with a BBUS and perhaps 5 minutes without. Shocked
Your steering lock probably adds a minute or two.
There are so many threads on improving security already on Def2 that there's really no point repeating them here, but a standard Puma is not secure in any sense of the word.
Post #696986 29th Mar 2018 5:08pm
Phil_C
Thanks black wolf, I'm not looking for a rehash of what security could be added etc. just questioning how goos factory standard is or isn't, and whether all Puma's had immobilisers or not.
I had been led to believe the immobiliser/chip was quite good when the key wasn't present - but if it is not then it looks like a remote cut off and some more visible deterrents are in the pipeline. 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
Post #696992 29th Mar 2018 5:23pm
X4SKP
Hello Phil_C
Approaches vary widely re Security... from the 'what will be will be' school of thought to the realisation that
'it really isn't that difficult to either unbolt stuff or drive it away, so I had better do something to improve my chances'...(school of thought Shocked ).
The Land Rover has lived through a time when it really wasn't an issue and most were effectively used with an open door policy to where we are now, with both a high profile end of life 'warm and fuzzy feeling' surrounding the Defender and vehicles now commanding unimagined prices...all this has drawn in the thieves who aim to prosper from the apparent easy pickings offered by Defenders.
So plenty on D2N to read through, and you must decide where you want to be on 'the spectrum'...
Many have decided that as Land Rover really only gave Defender Security 'an afternoons work', they must
take it to a more Secure state.
The other issue is that on approaching a Defender the assumption is (more or less) that they are all poor, and
present this easy target...make it non-standard, make it difficult, make it loud, oh and track it if all else fails
and you can at least feel that you have made a good attempt to hang on to it... especially as they aren't making
any more and who knows we all may just be driving round in the best that there may be...
The consensus is to apply layers, if in their own right they work, the more the better, some passive (they are just there working) and some active (you have to deploy them).
To answer your question...
The Key (actually Fob) 'hand shakes' with an induction loop around the ignition barrel, in theory No Fob No Ignition
but do not rely on this... Shocked
Good Luck SKIP
Post #696996 29th Mar 2018 5:40pm
The immobiliser is very basic and will probably cause you more trouble with failing-to-start issues that it will cause a would-be thief.
All modern cars incorporate a massive vulnerability in the form of the OBD port.
Post #696997 29th Mar 2018 5:52pm
zsd-puma
The actual key doesn't have a chip at all. The chip is in the plip (alarm remote), which dates from the mid 90's. My 20 year old Rover Mini uses the same plip - to give you an idea how modern it is.
They both help, but at the end of the day you've got a 45 year old ignition switch, with a 25 year old alarm system.
Post #697017 29th Mar 2018 7:03pm
Caterham
it's probably quite safe against someone looking to steal it armed with nothing more than a bags of chips and beef pie but if you're thinking it's safe against a targeted attack then all I can say is I hope you don't learn otherwise the hard way.
do all you can within reason if you're keen to hang onto it. Thumbs Up
Post #697033 29th Mar 2018 8:08pm
GrouseII
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
Hi
This is a subject I have spent a lot of time looking at and spending a few too many hundreds of pounds on thieves with add ons is very objectionable.
The long and the short of it is no matter how much you do the scumbags just need to pull up with a low loader and lifting strap and they are away.
Alas it seems a cross we have to bare for having excellent taste in vehicles!
Grouse2
Post #697072 29th Mar 2018 9:57pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi anyone - I love my «safe T pedal». Nothing more to worry 'bout. Cheers - Julie
Post #697078 29th Mar 2018 10:16pm
Except maybe a bump key or a cordless angle grinder.
Post #697082 29th Mar 2018 10:25pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Layers of good security is the key and as suggested earlier in this thread the more security that you have the harder it will be to for some lowlife scumbag to try and take from you Thumbs Up
One of my favourite security layers which I think has got to be one of the best visual deterrents is to remove the steering wheel via a quick release boss! I put my wheel in a backpack which makes it easier to carry about with me!
Without a doubt get a tracker as well with a smartphone app that will alert you if the vehicle moves !!
https://www.landroverdefendersecurity.com/...lease-boss
Good luck Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #697088 29th Mar 2018 10:41pm
ericvv
Really, nothing? Afraid there are no more certainties in this world.
Picture is about a forum member’s sorry experience a while ago... Crying or Very sad
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #697097 30th Mar 2018 5:34am
JOW240725
If they really want it they will have it. End of.
I think all you can do is add layers of security, enough to deter the theif to go to the next Defender with less layers. It's sad we have to, but it's just how it is.
Do what you can but still enjoy it! James
Instagram @suffolk_rovers
Post #697100 30th Mar 2018 7:34am
