Home > Puma (Tdci) > Central Locking 110xs
sjc501
Newbie here . My 110 recently purchased has developed a strange fault . When I use remote to lock it the two passenger doors don't always lock but they all unlock . Any ideas.? Thanks
Post #696368 26th Mar 2018 11:22pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Are they attempting to? Mine sometimes need a little grease on the mechanism to keep running smooth.
If you can hear the solenoid going on the press of the button, take the door card off and it should be obvious where to lube up.
Smile
Post #696374 27th Mar 2018 2:22am
mk1collector
The wires in the rubber boot between the post and doors that don't lock will be broken but still touching occasionally, it's a very common problem. Solder in better quality wire and it should last a long time. Ray
My build thread
Post #696409 27th Mar 2018 9:17am
BenB8man
^^That was my next step Smile
Post #696427 27th Mar 2018 11:26am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Jup two most likely steps 👍
Final step. Is to look if the actuator is pushing enough to make the lock click.
Perhaps bent rod Or Just LR tolerances Laughing i had to put 2 windings of tape on the eye of the actuator so it pushes the rod a fraction of a millimeter higher and that solved the problem. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696428 27th Mar 2018 11:30am
BenB8man
I won't claim to know about that one! 😉
That might actually help me also, it did seem like mine didn't quite have enough travel but seemingly didn't have any adjustment so assumed it must be correct. Lubricant has sorted it for now though.
Post #696429 27th Mar 2018 11:33am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Simple thing - check the trim pieces around the push up buttons they sometimes bind on the buttons and cause problems. Just remove them, and bend the button inwards. If the door cards have been removed/replaced this can happen - I know Rolling Eyes
Post #696453 27th Mar 2018 1:56pm
