![]() | Home > Puma (Tdci) > Central Locking 110xs |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Are they attempting to? Mine sometimes need a little grease on the mechanism to keep running smooth.
If you can hear the solenoid going on the press of the button, take the door card off and it should be obvious where to lube up. ![]() |
The wires in the rubber boot between the post and doors that don't lock will be broken but still touching occasionally, it's a very common problem. Solder in better quality wire and it should last a long time. Ray
^^That was my next step
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Jup two most likely steps 👍
Final step. Is to look if the actuator is pushing enough to make the lock click. Perhaps bent rod Or Just LR tolerances ![]() |
I won't claim to know about that one! 😉
That might actually help me also, it did seem like mine didn't quite have enough travel but seemingly didn't have any adjustment so assumed it must be correct. Lubricant has sorted it for now though. |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Simple thing - check the trim pieces around the push up buttons they sometimes bind on the buttons and cause problems. Just remove them, and bend the button inwards. If the door cards have been removed/replaced this can happen - I know
