Home > Td5 > Battery terminal to fit blue sea fuse bloick
alexatnd
Probably a simple question,
I'm buying a one of https://www.mudstuff.co.uk/blue-sea-fuse-block.html
these to attach to +ve battery terminal. Problem is the + terminal connectors ate the type that have battery cables connected via 2 screws and theres no option for mounting said fuse box horixontally and attaching it to the terminal .
Anyone else using the above fuse box?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #696211 26th Mar 2018 11:04am
alexatnd
o.k. found these
https://www.amazon.co.uk/Positive-Negative...B06VSCC71P Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #696214 26th Mar 2018 11:26am
X4SKP
Hello alexatnd
I have this Bluesea Fuse Box mounted on a Puma Batter.
May be different on a TD5 (if that is where you are installing it)...
The + Terminal looks like this for me with its 500AMP fuse and its main supply to the Starter Motor
and Power take off to the Main Fuses (under the drivers seat) and one other power take off for the
towing electrics installed.
The Bluesea (for me) sits on top of the main securing Terminal fastenings.
On this type of Battery Terminals they rely on a 'T' shaped Bolt that tightens a tapered collar, locking the Teminal.
I made up two new longer bolts, allowing a 'spacer element' to be included, this then allowed the Bluesea (+&-)
Units to sit just above the Batter top surface.
I also replaced the Battery Securing Bolts to short versions, as the long reach 'rods' would have got in the way
of the Bluesea elements...
May not help you much...but that's my 'set up'
Good Luck SKIP
Post #696258 26th Mar 2018 2:17pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Very helpful Skip, I too have tried to fit the blue sea box but was stumped by the short length of the bolts. Did you grind down a standard hex bolt to make it a t-bolt?
Post #696290 26th Mar 2018 5:34pm
X4SKP
Hello Scoobeenut
Exactly... thought I had a picture of it but apparently not,
from memory M6 SS Bolts around 50mm in length...'repurposed'.
There is a tendency to want to slightly over tighten these 'terminal bolts'
to ensure a good connection, so if you do the same start with a tough bolt
(8.8 or even 10.9)
Mine were ARP SS Bolts (from the Marine industry) that are effectively an equivalent
to a grade 8 Steel Bolt (SS can easily be weaker in tensile strength than steel).
Replacing these bolts to accommodate the Bluesea (nicely) overall makes the set up work,
as with most things in 'Defender World' there is a degree of 'adjustment' required to get things
just so.
Good Luck SKIP
Post #696400 27th Mar 2018 8:55am
