![]() | Home > Technical > LTB00386 - Defender Alarm Overlay Kit |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1494 ![]() ![]() ![]() |
The recent rise in thefts that have included cutting the power to the main fuse box is evidence that LR did indeed change the alarm wiring around 2012.
It also proves they have found a way round it, and the TSB. LTB000386. As Blackwolf says above, protecting the power supply to the fuse box is the next essential step in security after fitting a BBUS in the non standard position. |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1254 ![]() ![]() |
'As Blackwolf says above, protecting the power supply to the fuse box is the next essential step in security after fitting a BBUS in the non standard position'
A bit OT but how would I know if I have a BBUS fitted to a 2010 USW XS? Were they standard fitment? 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
I am no expert on copyright but if you found the stuff on on the web the gate has been opened and the horse has bolted it would be another matter if you were trying to sell it! |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
That’s why I only showed the part of the wiring diagram that was already in the TSB and nothing more. Dave
Green Goddess - 1998 Defender 110 300tdi |
Open the bonnet and hold down the alarm switch....set the alarm ..wait a minute then release the switch if thee is an alarm from the nearside wing you have a bbus. ....its an alarm and not a horn sound.... Bbus not standard fittment om your truck but loom there ...owner might have requested it though... |
![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Or check your build sheet or have a feel in your wing Mike
toetankh Member Since: 05 Aug 2015 Location: Papendrecht Posts: 22 ![]() ![]() ![]() |
Dear all,
Have been following this thread with interest and decided to take the plunge.... All installed according to the TSB, but.... For some reason the indicators don't flash anymore when using the keyfob to arm or disarm. Everything else seems to work fine: CDL, alarm sounder, bbus, I even hear the AS10 click once when disabling the alarm and click three times when enabling. What have I done wrong or what can I do to enable the indicator flashes again, before I start reverting everything back to original? Thanks! Sven |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
Check the hazard flashers work from the dash switch - if not then check fuse 31 in the main fuse box.
Thanks for the suggestion! Checked, but hazards are working fine (and so is fuse 31). I'll double check the new connection between the hazard-switch and the AS10, because that's the only thing I can think of that is causing the issue (being the feed for the hazard-relay in the AS10). I'd be surprised, but you never know...
Or am I overlooking something else? |
You fob's battery is dying - thats why they dont flash normally
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
The feed you've moved is the feed used to power the lights, not the feed used to switch on the feed to the lights. If you have a poor connection in your new link it will cause the symptom you describe.
Well Blackwolf, that seems to be the resolution! Thanks!
I somehow managed to make a connection that was good enough to measure 12,5 volts, but bad enough to not let through the current needed for flashing the indicators.... Sometimes.... I wish I drove a Saab ![]() |
