Home > Technical > LTB00386 - Defender Alarm Overlay Kit
Page 4 of 4 <1234
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Thanks Dave for confiming that part of my analysis.
Martin, I support the "publish exploits so we can find a solution" party.
I didn't post diagrams and details because of possible copyright, but more important because in this case I would not explain what the problem was (which we all should know about) but how LR's solution to it worked. This then might help the scum to find a new way around it. The part Dave posted is just one change that LR did to the alarm system. And I see no harm in posting that part. Also because it's the one directly related to the LTB in question.
Post #688362 23rd Feb 2018 9:16am
DSC-off
The recent rise in thefts that have included cutting the power to the main fuse box is evidence that LR did indeed change the alarm wiring around 2012.
It also proves they have found a way round it, and the TSB. LTB000386.
As Blackwolf says above, protecting the power supply to the fuse box is the next essential step in security after fitting a BBUS in the non standard position.
Post #688363 23rd Feb 2018 9:17am
seriesonenut
'As Blackwolf says above, protecting the power supply to the fuse box is the next essential step in security after fitting a BBUS in the non standard position'
A bit OT but how would I know if I have a BBUS fitted to a 2010 USW XS? Were they standard fitment? 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
1990 Defender 200tdi CSW (sold)
1989 Land Rover Ninety (sold)
1998 Discovery 2 (sold)
1995 Discovery 1 (auto) (sold)
1990 Discovery 200tdi (sold)
1987 One Ten CSW turbo diesel (sold)
Post #688364 23rd Feb 2018 9:26am
nitram17
I am no expert on copyright but if you found the stuff on on the web the gate has been opened and the horse has bolted it would be another matter if you were trying to sell it!
Post #688384 23rd Feb 2018 11:30am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
That’s why I only showed the part of the wiring diagram that was already in the TSB and nothing more. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #688385 23rd Feb 2018 11:39am
nitram17
Open the bonnet and hold down the alarm switch....set the alarm ..wait a minute then release the switch if thee is an alarm from the nearside wing you have a bbus. ....its an alarm and not a horn sound....
Bbus not standard fittment om your truck but loom there ...owner might have requested it though...
Post #688386 23rd Feb 2018 11:40am
seriesonenut
Thumbs Up 1984 One-Ten CSW
2010 XS USW (sold)
Post #688414 23rd Feb 2018 2:06pm
mse
Or check your build sheet or have a feel in your wing Mike
Post #688532 23rd Feb 2018 11:09pm
toetankh
Netherlands 2007 Defender 110 Puma 2.4 SW Stornoway Grey
Dear all,
Have been following this thread with interest and decided to take the plunge....
All installed according to the TSB, but....
For some reason the indicators don't flash anymore when using the keyfob to arm or disarm.
Everything else seems to work fine: CDL, alarm sounder, bbus, I even hear the AS10 click once when disabling the alarm and click three times when enabling.
What have I done wrong or what can I do to enable the indicator flashes again, before I start reverting everything back to original?
Thanks!
Sven
Post #695972 24th Mar 2018 9:58pm
Fifth Horseman
Check the hazard flashers work from the dash switch - if not then check fuse 31 in the main fuse box.
Post #696005 25th Mar 2018 6:27am
toetankh
Thanks for the suggestion! Checked, but hazards are working fine (and so is fuse 31). I'll double check the new connection between the hazard-switch and the AS10, because that's the only thing I can think of that is causing the issue (being the feed for the hazard-relay in the AS10). I'd be surprised, but you never know...
Or am I overlooking something else?
Post #696033 25th Mar 2018 12:30pm
mse
You fob's battery is dying - thats why they dont flash normally Thumbs Up Mike
Post #696036 25th Mar 2018 12:45pm
The feed you've moved is the feed used to power the lights, not the feed used to switch on the feed to the lights. If you have a poor connection in your new link it will cause the symptom you describe.
Post #696038 25th Mar 2018 1:07pm
toetankh
Well Blackwolf, that seems to be the resolution! Thanks!
I somehow managed to make a connection that was good enough to measure 12,5 volts, but bad enough to not let through the current needed for flashing the indicators....
Sometimes....
I wish I drove a Saab
Very Happy
Post #696047 25th Mar 2018 2:38pm
Page 4 of 4 <1234
