Romadog
ground points under bonnet on bulkhead near wings.
24th Mar 2018 7:45pm |
hornet
Re: Ground/Earth points for central locking | |
the.enterprise wrote:Hi there, can someone point me on the right direction about where the ground points are?
I'm planing on retrofitting central locking to the 90 via the AS10, which was already reprogrammed to accept it.
I've got the diagram about where to connect the pink, orange and yellow wire, but not sure where to connect the ground.
Is there any ground point behind the dash? Or somewhere near that area? Or can I just use any hole in the bulkhead, scrape the paint a little bit, and add a ground point?
Or should I hook it up to an existing ground wire on the main loom?
Many thanks
http://www.defender2.net/forum/topic48404.html
check post #9
27th Mar 2018 11:44am |
