Home > Puma (Tdci) > Studs exhaust manifold to turbo keep coming loose
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
In the next couple of weeks am going to a workshop to do some maintenance. And I want to tackle this problem once and for all.
The problem is that the studs are coming loose mainly in the summer and on load (caravan, 4 kids, mountains etc). Not the bolts but the studs.
What have I done so far.
1. Fitted the thick spacer (bought it at alive)
2. Got bigger studs m10
All with no succes.
Any ideas?
I run an alive remap, with a bespoke turbo, allisport radiator, allisport intercooler, decat, 100 mm air intake a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #694852 20th Mar 2018 9:31am
Low-Range
Canada
loose studs
You can buy a compound that you put on the threads before you tighten them. http://www.all-spec.com/UserFiles/Images/P..._WebXL.jpg
Post #695024 20th Mar 2018 9:38pm
Tdi4
Thnx!
But is it sufficient temperature resistant? As far as I can see ir’s Rated > 300 degrees. But the exhaust manifold will reach > 800 degrees? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695031 20th Mar 2018 9:50pm
Low-Range
Canada
studs
Different products have different ranges.. https://pilotshq.com/loctite-superflex-red...11054.html
Post #695033 20th Mar 2018 9:56pm
Tdi4
Correct but this product is rated to 315 degrees. I haven’t found a product which can withstand the temperatures of a exhaust manifold. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695057 20th Mar 2018 10:29pm
I suspect the problem is caused by the studs expanding more/faster than the flange through which they pass, thus reducing the tightness of the nuts, in turn allowing the nuts to loosen more. I have always had a similar problem with the studs securing the front branch of the manifold to tne head, now exacerbated by the failure of the thread in one hole in the head (I will be fitting a Timesert to this when I get time, but inevitably it is the hole behind the alternator bracket so a lot of dismantling is required to get at it).
You may find that fitting longer studs with a spacer of a different material with a greater coefficient of linear expansion, such as a hard brass, between the nuts and the flange does the trick. The idea (fairly obviously) is that by expanding a little faster than the stud the spacer maintains the tension needed to prevent the nut loosening.
Post #695085 20th Mar 2018 11:48pm
Tdi4
Thnx Blackwolf,
Sorry but I can’t figure out where to put the spacer. Stud goes into manifold and then??? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695112 21st Mar 2018 6:54am
Longer stud into manifold, turbo onto studs, spacer onto stud, nut onto spacer.
A very similar thing is often done on where TD5 exhaust manifolds bolt to the head to prevent the studs from breaking for similar reasons.
Post #695143 21st Mar 2018 9:37am
Tdi4
Okay will try that (as well Laughing ).
But I'am trying to understand this solution, if it works I don't need to understand it. But what is different? The bolt is put on tight but still the stud comes loose. What is the function then of the washer? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695148 21st Mar 2018 10:18am
grafty99
I have blocks on my Td5, it's worked for the last 5 years Thumbs Up
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #695154 21st Mar 2018 10:35am
Tdi4
Hi Grafty,
Are those stretch bolts? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695155 21st Mar 2018 10:44am
grafty99
No just standard 8.8 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #695173 21st Mar 2018 1:25pm
Tdi4
Hi grafty
Then I didn’t understand you correctly. Another Dutch guy trying to speak English Laughing
What are blocks? I ‘ve looked at the picture and I didn’t see anything else than the bolts? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695217 21st Mar 2018 5:04pm
grafty99
There are cylindrical metal blocks which the bolts pass through before the manifold face Thumbs Up
I'll edit the picture to explain better Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #695310 21st Mar 2018 10:06pm
grafty99
The section in red is the block which expands to keep tension on the bolts Thumbs Up
1990 Vogue SE
Post #695334 21st Mar 2018 10:47pm
