![]() | Home > Puma (Tdci) > Studs exhaust manifold to turbo keep coming loose |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
In the next couple of weeks am going to a workshop to do some maintenance. And I want to tackle this problem once and for all.
The problem is that the studs are coming loose mainly in the summer and on load (caravan, 4 kids, mountains etc). Not the bolts but the studs. What have I done so far. 1. Fitted the thick spacer (bought it at alive) 2. Got bigger studs m10 All with no succes. Any ideas? I run an alive remap, with a bespoke turbo, allisport radiator, allisport intercooler, decat, 100 mm air intake a defender from 1984 pretending to be a puma with a touch of Range Rover |
Low-Range Member Since: 30 Sep 2016 Location: BC Posts: 41 ![]() ![]() |
You can buy a compound that you put on the threads before you tighten them. http://www.all-spec.com/UserFiles/Images/P..._WebXL.jpg
Thnx!
But is it sufficient temperature resistant? As far as I can see ir’s Rated > 300 degrees. But the exhaust manifold will reach > 800 degrees? a defender from 1984 pretending to be a puma with a touch of Range Rover |
Different products have different ranges.. https://pilotshq.com/loctite-superflex-red...11054.html
Correct but this product is rated to 315 degrees. I haven’t found a product which can withstand the temperatures of a exhaust manifold. a defender from 1984 pretending to be a puma with a touch of Range Rover
Thnx Blackwolf,
Sorry but I can’t figure out where to put the spacer. Stud goes into manifold and then??? a defender from 1984 pretending to be a puma with a touch of Range Rover |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17738 ![]() ![]() ![]() |
Longer stud into manifold, turbo onto studs, spacer onto stud, nut onto spacer.
A very similar thing is often done on where TD5 exhaust manifolds bolt to the head to prevent the studs from breaking for similar reasons. |
Okay will try that (as well
![]() But I'am trying to understand this solution, if it works I don't need to understand it. But what is different? The bolt is put on tight but still the stud comes loose. What is the function then of the washer? a defender from 1984 pretending to be a puma with a touch of Range Rover |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
I have blocks on my Td5, it's worked for the last 5 years
![]() ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Hi Grafty,
Are those stretch bolts? a defender from 1984 pretending to be a puma with a touch of Range Rover |
No just standard 8.8
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Hi grafty
Then I didn’t understand you correctly. Another Dutch guy trying to speak English ![]() What are blocks? I ‘ve looked at the picture and I didn’t see anything else than the bolts? a defender from 1984 pretending to be a puma with a touch of Range Rover |
There are cylindrical metal blocks which the bolts pass through before the manifold face
![]() I'll edit the picture to explain better ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
The section in red is the block which expands to keep tension on the bolts
