Home > My Defender > Grafty's Td5 90
Page 67 of 124 <123 ... 666768 ... 122123124>
L110CDL
Tell me about it, i was always glad when the warmer weather was about Wink Clayton.
Keeper.
Post #694785 19th Mar 2018 10:57pm
Profyaffle
I think I may have opened a can or worms Laughing
Anyway.. will we get to see some pics of the webasto install ? 1993 200Tdi Defender 90
Post #694794 19th Mar 2018 11:47pm
Profyaffle
Did you rivet you dirt defenders on? or attach them with something else... ? 1993 200Tdi Defender 90
Post #694799 20th Mar 2018 12:02am
grafty99
Webasto pics coming soon Thumbs Up
Dirt defenders were riveted on yes. I drilled the holes and then painted them to prevent corrosion. Then when I installed them I applied grease to the rivets Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #694833 20th Mar 2018 8:27am
grafty99
Well today really has not been a very good day at all.
Ever since I changed my coolant in January I have had great difficulty bleeding all of the air out of the system. And for the first time ever this happened.........
Big Cry Big Cry
Anyway today I tested for combustion gas in the coolant and unfortunately it would seem that there is. So there we have it. After 127,000 miles I have had my first major fault with my defender Big Cry Big Cry Big Cry
Will now park it up and focus on getting the range rover on the road. Once I have transport then I'll take the head off the defender and see what happens.
Looks like Mondays Cornwall meet will have to be in a different landrover product Rolling Eyes
Did I mention? Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #697258 30th Mar 2018 6:16pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Run hose full on in header bottle with bleed open
Once de aired drain a bit out of header and add coolant 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #697267 30th Mar 2018 7:00pm
grafty99
Yeah I've done all that, including having it vacuum bled.
Unfortunately exhaust gas is getting in and creating air locks, it's only now that I've had a chemical test kit on it and confirmed that there is a problem.
I change the coolant every 2 years regardless and have never had a problem bleeding the system before. Thats why I had a hunch there was a problem looming. I'm guessing that the gas leak had just started when I changed the coolant and has progressively gotten worse over the last few weeks whilst I've been bleeding the system a lot! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #697269 30th Mar 2018 7:08pm
Procta
Censored head gasket on its way? Be worth seeing if you can get an up rated one plus you can see if you can get some head work done.
check the dipstick for mayno Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #697273 30th Mar 2018 7:41pm
grafty99
No other symptoms. All the fluids are staying in their correct places. Just combustion gas leaking into the coolant system. It's either a failed gasket or cracked head (Or both)
If it's a cracked head then I'll be getting a ported and flowed one from Turner Engineering Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #697282 30th Mar 2018 8:00pm
pj2106
Have you check fuel cooler and if you still have egr cooler?
Did you get payment for the vents bud? 2008 110 2.4 XS Utility (Hagrid)
Post #697297 30th Mar 2018 8:25pm
grafty99
Fuel cooler and EGR cooler both ok. Money received thank you - will send out on Tuesday Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #697306 30th Mar 2018 8:33pm
Procta
yeah i had that with the rover metro, If you have the budget to get the head ported and flowed, even though it turns out to be spot on. Its worth doing while its off, maybe even have a look at the bottom end too, Thumbs Up
If you can sort out a replacement head, before you replace the head gasket, then why not just send the replacement head away for work, then it would be near enough a case of plug and play Thumbs Up
but preper to go over budget though, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #697434 31st Mar 2018 2:19pm
grafty99
It a landrover, there is no budget Laughing
I'm only planning on doing this once so I'm not going to be cutting corners. Whatever it costs then I'll get it done. I've been looking at the AMC head from Turner Engineering. It comes pre ported and flowed as far as I'm aware Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #697450 31st Mar 2018 4:39pm
Procta
well there is your answer there, Thumbs Up fewer question marks the better for you. I budget 1k on my rover metros head gasket, ( it was a vvc) I did go over that by nearly 500! That was getting the daft odds and sods, but also diagnostic. Which turned out to be dirt in the inlet Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #697452 31st Mar 2018 4:55pm
ibexman
That looks like a nice bit of engineering George good luck with the rebuild Thumbs Up
Post #697454 31st Mar 2018 5:00pm
