![]() | Home > Maintenance & Modifications > Windscreen frame corrosion |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
I’ve had this once and no doubt it will come back. I think part of the trouble is the windscreen rubber doesn’t really keep the water out, rather it traps it against the paint. The surround is also aluminium or similar which the paint doesn’t stick to well.
I would like to find a permanent fix. One thought that occurred was a windscreen surround made of a different material, or a better seal? Not sure if anything is available commercially. 2014 Keswick Utility 2.2 |
Grapax Member Since: 19 Nov 2016 Location: St Neots Posts: 77 ![]() ![]() ![]() |
I have a 2014 110 and this has small bubbled paint area on windscreen also, it’s booked in for warranty repair next month so hope this gets sorted first time, but this does sound like an issue many other owners have found
JASON B Member Since: 01 Jan 2018 Location: Oxfordshire Posts: 19 ![]() ![]() ![]() |
Make sure they completely seal the windscreen rubber to frame and all the foam seals to bulkhead and roof, also fit some ally billet brackets and good luck, went to Marshall Landrover today and they took some photos, it’s got to be a faulty frame for the corrosion to come back for third time since December 2017 my poor old roof has got to be lifted again , another week in the garage, it’s getting a bit embarrassing now
Thanks for advise
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
It's been interesting to read the the posts on corrosion and required warranty work on some of the newer Defenders. I have a 2003 and apart from the door bottoms the paintwork is still very good all over with no localised areas of rust and paint failure. So why is this happening ?. The transition from solvent to water based paints circa 2007 ? The paint thickness? The preparation of the body prior to painting? The quality control of the production line? Any thoughts?
Possibly paint thickness , what about storage of the windscreen frames as they are cast aluminium any slight damp in warehouse or transportation even the paint shop, 2 weeks after the new frame was fitted the seams on the gutter slightly opened up causing paint to split then corrosion set in , so is it a faulty frame, this is an issue that Landrover need to look into
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2153 ![]() ![]() ![]() |
My local paint shop has done several defenders over the last couple of years all with the same issue and only on one side
He feels that the problem is the way that the windscreen is fitted in the factory - the pain inside is scratched and the seals are not a perfect fit so with the scratched side and some dampness the corrosion sets in ... (just had mine done this month ...!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
That’s interesting the original factory fitted frame was ok on the gutter for corrosion, the reason it was replaced the first time was corrosion from the brackets, and now I’ve got problems with corrosion on which looks like a seam , but I see what you mean if they pull that cord round to fit new screen it will scratch the paint.
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
I'm told that vehicles with heated screens suffer the worst because the glass is thicker and the windscreen rubber doesn't seal as well as non heated.
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
My 2012 is going for its second and final windscreen frame and rear door. In fact they´ll be swapping out one complete tub side as well. It really is pathetic how bad the replacement parts are, and how quickly they corrode again. My dealer is quite conscientious and tries to improve on JLR´s quality, but still can´t seem to make much difference.
The corrosion is all minor stuff on the surface but it is obvious how it will develop if not attended to. Fluid film and various treatments aren´t enough to counter the poor factory quality. My Landy gets to see quite a bit of salt, and even though I wash it off regularly, the results after each winter are disappointing. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
Mine is not heated, had some excellent news today Marshall Landrover are going to replace the complete windscreen frame again and all the parts required at their Newbury bodyshop in approx 3 weeks
I,d be disappointed if I brought the new Landrover 70th edition for £150000 and the corrosion problems started to happen
Bodged mine. Dread to think what dealers do to repair this fault. I'd rather do this than have the worry.
Can’t understand why Landrover has not done anything about this as the dealerships have replaced loads of these time and time again, the defender is an excellent vehicle and not exactly cheap to buy , mine is immaculate I wash and wax it regularly and then the dreaded corrosion comes back in the same place, which means another trip to dealers and another week being repaired, surely there is a cure or an alternative to this problem
