![]() | Home > Maintenance & Modifications > Boomslang Loom replacement relay |
That looks like a standard 30amp changeover relay. I don't think the 'H4458' is useful here, as it appears on both 4 and 5 pin relays.
![]() Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
HELLA 007794311 12V 20/40 Amp SPDT RES Relay with Weatherproof Bracket by HELLA
Benmatt912 Member Since: 05 Jan 2014 Location: Worcestershire Posts: 33 ![]() ![]() ![]() |
Here is a picture of the diagram on the current relays, interestingly one is 4 pin and the other is 5 pin and only 4 of the pins are used.
Hi all, I’ve manage to get it sorted.
Thanks to LandRoverAnorak and dorsetsmith for there help. In case anyone else in the future gets the same problem this is what I ordered:Standard relay change over 40 30 Amp 5pin R2032C-1 https://www.electricalcarservices.com/stan...OcQAvD_BwE They seem to work so far. Ben |
