Home > Maintenance & Modifications > Boomslang Loom replacement relay |
That looks like a standard 30amp changeover relay. I don't think the 'H4458' is useful here, as it appears on both 4 and 5 pin relays.
Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Mar 2018 4:59pm |
HELLA 007794311 12V 20/40 Amp SPDT RES Relay with Weatherproof Bracket by HELLA
11th Mar 2018 5:07pm |
Benmatt912 Member Since: 05 Jan 2014 Location: Worcestershire Posts: 32 |
Here is a picture of the diagram on the current relays, interestingly one is 4 pin and the other is 5 pin and only 4 of the pins are used.
Click image to enlarge |
11th Mar 2018 5:14pm |
Hi all, I’ve manage to get it sorted.
Thanks to LandRoverAnorak and dorsetsmith for there help. In case anyone else in the future gets the same problem this is what I ordered:Standard relay change over 40 30 Amp 5pin R2032C-1 https://www.electricalcarservices.com/stan...OcQAvD_BwE They seem to work so far. Ben |
14th Mar 2018 6:10pm |
