Home > Td5 > Break inertia switch circuit to disable Defender
Page 3 of 4 <1234>
dorsetsmith
2.4 inertia switch is inside 10AS alarm i believe may be wrong
Post #675448 3rd Jan 2018 6:04pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Just reading this thread with interest as seen this
https://www.landroverdefendersecurity.com/...f-2-2-tdci
Wondering how easy it is to fit. Where would it fit and how would you get the wireing into the cab safely? My biggest concern is knocking the switch while driving. Especially with the location I would ideally want to fit.
Post #691273 5th Mar 2018 9:49pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Interesting. They must have read this thread Smile
I share your safety concerns.
You could use a locking switch instead. However, it has to lock in the ON postion. I have modified this http://www.mudstuff.co.uk/products/carling...k-789.html to lock in both positions (for a different purpose).
Or a rotary switch.
Or two switches, mounted not close to each other.
Or any other kind of switch that isn't easily operated
http://www.instructables.com/id/Frankenstein-Light-Switch/ Very Happy
Post #691305 5th Mar 2018 10:49pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
This is a mod I've been considering for my Td5 90.
I was thinking of adding a small discreet button somewhere out of the way, wired to energise a small relay fed from the ignition live to make the connection through the inertia switch, that way there is no need to switch anything off when leaving the car, just need to press the button before starting once the ignition is on.
Post #691487 6th Mar 2018 6:38pm
Screbble
I've sent you a PM Clive Thumbs Up
Post #691491 6th Mar 2018 6:48pm
Clive
Cheers Will, answered Thumbs Up
Post #691502 6th Mar 2018 7:23pm
roel
In a previous car I had to put full beam and the alarm lights on at the same time and then I had about 10 minutes to start it. If I switched it off I could restart it within 10 minutes after that I had to use the same procedure.
About 2 years after I sold it a small problem occured. It switch itself off after 10 minutes while driving. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #691517 6th Mar 2018 8:04pm
macfrank
Exactly why I think safety should be considered here and a cheap little switch might not be enough.
It's about assessing risks. It might work ok for a long time, but if and when it fails it can be devastating.
But hey, I'm German - can't help thinking that way; bloody genes... Wink
Post #691606 6th Mar 2018 11:16pm
roel
Changed 1 relais and the problem was solved. The buyer just didn't understand the system. Roel
Post #691788 7th Mar 2018 8:24pm
nitram17
I don't mind admitting I do not know how you did this....any chance of a diagram ...product list..via pm if your prefer... Thanks in advance...
Post #691833 7th Mar 2018 10:54pm
vulcanfreak
2006 Defender 90 Td5 Silver LE Zambezi Silver
I think that the longer this thread stays in the public domain, the less effective this security feature becomes.
Post #691866 8th Mar 2018 8:02am
nitram17
Cats out of the bag i am afraid Big Cry when there is a commercial product on the market.........I will keep my switch in place but my faith in its utility has diminished ..but i guess its one more thing for the Censored to take a minute or so to bypass.......shhhh dont tell anyone but you could deploy the commercial product but also interupt the wire further up the chain...so when the Censored look for the commercial product and bypass it ..the other switch kicks in......... Whistle
Post #692109 9th Mar 2018 2:14am
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Is this the switch or just the reset? 2.2 puma engine.
 Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #692982 13th Mar 2018 1:05am
nitram17
That's the inertia switch. Thumbs Up .....
Post #693000 13th Mar 2018 8:09am
Procta
does the td5 have a starter relay? Rovers have them, its a little black box with two plugs. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #693224 14th Mar 2018 11:13am
Page 3 of 4 <1234>
