![]() | Home > Td5 > Break inertia switch circuit to disable Defender |
2.4 inertia switch is inside 10AS alarm i believe may be wrong
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Just reading this thread with interest as seen this
https://www.landroverdefendersecurity.com/...f-2-2-tdci Wondering how easy it is to fit. Where would it fit and how would you get the wireing into the cab safely? My biggest concern is knocking the switch while driving. Especially with the location I would ideally want to fit. |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1135 ![]() ![]() ![]() |
Interesting. They must have read this thread
![]() I share your safety concerns. You could use a locking switch instead. However, it has to lock in the ON postion. I have modified this http://www.mudstuff.co.uk/products/carling...k-789.html to lock in both positions (for a different purpose). Or a rotary switch. Or two switches, mounted not close to each other. Or any other kind of switch that isn't easily operated http://www.instructables.com/id/Frankenstein-Light-Switch/ ![]() |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
This is a mod I've been considering for my Td5 90.
I was thinking of adding a small discreet button somewhere out of the way, wired to energise a small relay fed from the ignition live to make the connection through the inertia switch, that way there is no need to switch anything off when leaving the car, just need to press the button before starting once the ignition is on. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2337 ![]() ![]() ![]() |
I've sent you a PM Clive
Cheers Will, answered
Exactly why I think safety should be considered here and a cheap little switch might not be enough. It's about assessing risks. It might work ok for a long time, but if and when it fails it can be devastating. But hey, I'm German - can't help thinking that way; bloody genes... ![]() |
Changed 1 relais and the problem was solved. The buyer just didn't understand the system. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
I don't mind admitting I do not know how you did this....any chance of a diagram ...product list..via pm if your prefer... Thanks in advance...
vulcanfreak Member Since: 05 Sep 2010 Location: suffolk Posts: 77 ![]() ![]() |
I think that the longer this thread stays in the public domain, the less effective this security feature becomes.
Cats out of the bag i am afraid
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
Is this the switch or just the reset? 2.2 puma engine. ![]() Click image to enlarge Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
That's the inertia switch.
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5369 ![]() ![]() |
does the td5 have a starter relay? Rovers have them, its a little black box with two plugs. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
