![]() | Home > My Defender > Grafty's Td5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
Great news on the new MOT
![]() ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Yes, always a nervous time. Not so much the MOT itself but leaving my defender in the hands of someone else. All came back ok though which is good
![]() Earl Grey tea and Fortnum & Mason buiscuits for the upcoming deal - what do you reckon Clayton? ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
The next deal needs a bit of tweaking but there is a working (sort of) prototype
Moving along nicely then
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5321 ![]() ![]() |
what about the rest of the forum? ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Anyone from the forum who comes over can have tea and biscuits. It's a long way for a cuppa though procta
you can post it
Ok lads hire a large mini bus! Tea and biscuits at georges! You would die if everyone turned up mind ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
We have commercial catering facilities at the campsite so I'm sure I could cope
Mc071963 Member Since: 06 Jan 2018 Location: Hertfordshire Posts: 48 ![]() ![]() ![]() |
Hi grafty99
wonder if you can help. I really like your mod's with the indicator stalks and the light stalk. I have a pair of stalks but am struggling to figure out the actually function of the switches. Do you happen to have any info on the pinout of the two stalks ? Cheers Martin TD5 90 in Hertfordshire |
Hi Martin.
I'm not sure about the stalk pinout as I had the two vehicles side by side. All I know is that the wire colours were the same. The LH stalk is identical in function to the defender item. The RH is the same except the slider adjusts the resistance through the intermittent wire and pulling the stalk towards you puts the wipers on constant for as long as you hold it. Hope that helps? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
How did you get them to work with self cancel? I have toyed with the idea of doing this to mine at some point, but then again I don't know much difference there is with the 300 and TD5 electrics wise. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
The self cancel works off the steering wheel the same as before. You have to change the cancel pins slightly but other than that it's pretty easy
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
I'm all caught up with your thread again... looking beautiful.. the landy...
