Home > Maintenance & Modifications > Jack and associated gubbins.
Page 2 of 3 <123>
donmacn
This maybe isn't the place, but I'll echo what Mo has just said about the high lift being dangerous.
A few years ago I got stuck in the snow at the side of a wee road up in the hills of Speyside. Long story - trying to get round a spun and jammed Transit sitting across the road; wee small hours; no-one around; blizzard conditions.
I had practiced with the jack before - but in the dark, with lots of task-loading going on I forgot to clip the handle up. My plan had been to 'walk' the car sideways back onto the road. Jack handle came up under load, got me right across the right side of my face. I was nearly knocked out - swaying on my feet and literally 'saw stars' - but I was really very lucky. I broke my cheekbone in three places - but an inch either way and I could have been dead, or had my nose taken off completely. I could have been knocked out in the snow and died of exposure.
I've now bought a nice, straightforward LR bottle jack and will one day sell the Hi-lift. It's obviously a great tool in the right context - but not without its risks. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #689668 28th Feb 2018 5:48pm
I've said it before and I'll say it again, it isn't the jack that is dangerous, it is the person using it.
No different to a power tool, chainsaw, or for that matter shotgun.
This isn't intended to sound unsympathetic, donmacn, that must have hurt lots and been a nasty shock, but with the greatest respect it wasn't the jack's fault.
Post #689669 28th Feb 2018 5:52pm
Should have gone to spec savers Mo. I never said any such thing. I mentioned that the bottle jack overall is safer. The Hi Lift is safe when used responsibly and in the right situation can prove useful especially off road and on green lanes. Over all the bottle jack is a best all rounder, but I like to have both to suit situation.
You can also use both as a fail safe if need.
It’s worth bearing in mind the Sprinter jack is also a bit taller than OE. So I am not sure how well you’d come off with a puncture and reduced axle height, can anyone confirm?
This was why I went for the genuine bottle jack, and got a good price as well. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689674 28th Feb 2018 6:41pm
miker
Bought a disco bottle jack to replace the useless wind up that came with mine. Works great, easy to use, quick and useful in other jobs/vehicles. Like that time I popped a trailer tyre!
Post #689714 28th Feb 2018 8:11pm
I think the disco one mentioned above is identical as far as I can tell except for colour to a new Def one.
Possibly the handle may be different but they both do the job perfectly. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689717 28th Feb 2018 8:18pm
Grouse
The screw thread pillar jack is slow, but it does the job, is safe and does have its benefits.
30 years ago, my 110 V8 County was bogged to its axles in mud off road. The pillar jack enabled me to jack the vehicle up and out of the mud and throw a load of stone under the front axle so that I could drive out. The large jack pad prevented it sinking and I remained clean and safe.
I wouldn't have been able to use the std bottle jack as I couldn't get under the axles due to the mud, and even if I had, the small jack base would have sunk in the mud, disappeared and I would have been on my knees covered in mud.
Yes, the screw pillar jacks are slow, but they work and are safer than a hi-lift in inexperienced hands - plus the vehicle came with it and no additional purchase was necessary.
For road use the bottle jack is best, but for all round use including off road I would take the screw pillar jack in preference. It's only down side is that it is painfully slow and large. The best option is to have both.
Post #689733 28th Feb 2018 9:08pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If worried about using the bottle jack off road just keep a good block of wood in the back, I have done since seeing how effective it is Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #689764 28th Feb 2018 9:55pm
Mo Murphy
I'm back from Specsavers, reread your posts and your first post still recommends a Hi lift jack as a tool for changing wheels on the road as the OP was requesting advice for ! In fact the OP specifically said he didn't want a Hi lift Laughing Embarassed Thumbs Up
However, I've learned from this exchange. Good luck changing wheels on the road with a Hi lift, I look forward to viewing it from a safe distance Thumbs Up
50 Shades of Pennine Grey
Post #689770 28th Feb 2018 10:00pm
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689773 28th Feb 2018 10:03pm
Grouse
I already do that - I have an 18" square piece of 1" marine ply. The trouble is there are times that you simply cannot get a bottle jack under the axle - such as if it's bogged knee deep in mud Thumbs Up
Post #689784 28th Feb 2018 10:16pm
^^^^ This is my point, the same applies with deep ruts as well.
That's why I like both, currently I've got just the bottle jack but will be getting a hi lift too.
Regardless of what ever jack you do use, none are to be trusted or disrespected. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689801 28th Feb 2018 10:48pm
No problem changing a wheel with a Hilift, just bung a strap round the axle and chassis by the wheel you're changing so it comes off the ground before the opposite side starts to lift.
Post #689822 28th Feb 2018 11:37pm
Mash
If it’s that bad we could go down the air bag jack route Laughing so many options depending on needs and conditions, but I think the best advice for the question in hand comes back as a Land Rover bottle jack. Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #689845 1st Mar 2018 12:48am
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Re: Jack and associated gubbins.
Badger110 wrote:
I've found out my new purchase came without the jack and associated bits n bobs in case of a flat at the roadside scenario etc.
What does one recommend i look for as a suitable replacement? i'm not looking for a highlift for this kind of scenario ( i may purchase one later on for off road ) just a decent jack set up.
is it worht looking for an original one or aer they not very good?
Thought my 110 was the same found the jack under the passengers seat.
Post #690296 2nd Mar 2018 7:09pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I looked and unfortunately i just have the chock and no jack Sad
Post #690378 2nd Mar 2018 11:23pm
Page 2 of 3 <123>
