![]() | Home > Technical > Fuel gauge accuracy |
GrouseII Member Since: 29 Dec 2017 Location: Bucks Posts: 37 ![]() ![]() ![]() |
I would guess the gauge or the sender is faulty rather than it is a design fault.
If it were a design issue then I would expect to see more complaints on this forum. Just got back myself from Scotland .... awesome place, love it! Grouse |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I'm guessing the senders are the same design as most of that era. Bits of wire wrapped around a plastic bit. The wires wear through and gives all sorts of wild readings.
Here's one from my mini last year, I expect the same thing has happened to the sender in yours. ![]() Click image to enlarge |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello dioliahary
My 300tdi fuel gauge was also...shall we say 'vauge', initially I tended to rely on the trip millage gauge to give me an idea of what was left in the Defender. The habit has stuck around with the Puma, and for my 90, under normal driving I can rely on just over a 300 mile range if need be. On our first 'adventure' I loaded up Jerry can, which did wonders to provide the feeling that you were actually heading off into the wilderness, but in truth, I have only used it once to help another motorist (mid winter in the Lakes) but the fact you have it... absolutly take away the anxiety of will she or wont she make it to the next filling station. 20lts / 3.2 gals = 80 Miles ![]() ![]() Click image to enlarge Should be enough to get you out of trouble... SKIP https://www.defender2.net/forum/topic83242.html |
20 litres = 4.4 Imperial gallons
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks Darren...you are right, so I have 100+miles in reserve...
![]() + a wee dram in one of these... ![]() https://www.defender2.net/forum/topic83242.html |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
Great stuff thanks and Jerry can it is 👍 1990 200tdi conversion 90
