Home > Maintenance & Modifications > Puma 110 UJ TVC500010G
Bluest
Is TVC500010G suitable for both front and rear props on a 2007 Puma 110? 2007 110 TDCi Station Wagon XS
Post #689105 26th Feb 2018 9:08pm
Bluest
Anyone? The reason I ask is that the parts supplier says they are fine for either prop, and I thought they were different front and rear. 2007 110 TDCi Station Wagon XS
Post #689323 27th Feb 2018 4:36pm
Looking in the Parts Catalogue TVC500010 is given as the same for 90 or 110 on the front and for the 90 on the rear but 110 & 130 rear is listed as RTC3458.
Post #689515 28th Feb 2018 10:11am
I think it is TVC100010 the rear UJ, which is a smaller joint than the front (75mm across faces with 27mm diameter caps, and opposed to 94.5mm and 30mm for the TVC500010 front UJ).
I always buy my propshaft UJs from Dingocroft, and always opt for the heaviest duty GKN versions available.
Post #689518 28th Feb 2018 10:26am
Bluest
This rather annoying. A well respected Lr accessory company and I went back to double check and they insisted they were right for front or rear! Grrr! 2007 110 TDCi Station Wagon XS
Post #689679 28th Feb 2018 6:57pm
