![]() | Home > Maintenance & Modifications > Puma 110 UJ TVC500010G |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
Anyone? The reason I ask is that the parts supplier says they are fine for either prop, and I thought they were different front and rear. 2007 110 TDCi Station Wagon XS
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Looking in the Parts Catalogue TVC500010 is given as the same for 90 or 110 on the front and for the 90 on the rear but 110 & 130 rear is listed as RTC3458.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18049
I think it is TVC100010 the rear UJ, which is a smaller joint than the front (75mm across faces with 27mm diameter caps, and opposed to 94.5mm and 30mm for the TVC500010 front UJ).
I always buy my propshaft UJs from Dingocroft, and always opt for the heaviest duty GKN versions available. |
This rather annoying. A well respected Lr accessory company and I went back to double check and they insisted they were right for front or rear! Grrr! 2007 110 TDCi Station Wagon XS
| All times are GMT |
