Home > Maintenance & Modifications > Jack and associated gubbins.
Page 1 of 3 123>
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I've found out my new purchase came without the jack and associated bits n bobs in case of a flat at the roadside scenario etc.
What does one recommend i look for as a suitable replacement? i'm not looking for a highlift for this kind of scenario ( i may purchase one later on for off road ) just a decent jack set up.
is it worht looking for an original one or aer they not very good?
Post #689414 27th Feb 2018 9:05pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Mercedes Sprinter bottle jacks get many recommendations from forum members
Post #689416 27th Feb 2018 9:09pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I use the original bottle jack, have used them for years, should be able to find them easily on ebay, disco 1/2 has the same bottle jack. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #689419 27th Feb 2018 9:21pm
Hi Lift and genuine bottle jack.
Contact Thornton Breakers regarding one, they are pretty good of genuine jacks. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689423 27th Feb 2018 9:26pm
Badger110
Cheers all,
original or sprinter seems to be the options, i'll take a look at both Very Happy
Post #689469 27th Feb 2018 10:54pm
rockster57
Be careful if you order an “original” jack since original on some models is a hydraulic bottle jack but on others it is the mechanical spiral wind-up variety.
Post #689476 27th Feb 2018 11:27pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Trolley jack if you are concerned about ease of changing roadside punctures (the wife has a nice Sealey 2 tonne one in a plastic carry case) or a high-lift if you want to change anything off road as everything else is usually a waste of time on any sort of soft ground.
Personally I buy good quality tyres (usually BFG) and have not had a roadside flat on any of my vehicles in about 20 years with the sole exception of a cheap tyre on my old pickup that I ripped open on a jagged bit of metal sticking out of an unmade road. Picked up a few nails here and there but decent tyres usually hold them in and just have a very slow leak which you can repair when convenient.
If you want a bottle jack the main thing is to enjoy getting dirty under the vehicle and make sure you get a 2-stage one as almost all off the shelf bottle jacks are completely useless for a Defender. The Discovery Tdi jacks are not a bad option.
Do not under any circumstances opt for the spiral wind-up jack. It takes about three weeks to change a wheel and guaranteed you will throw it in the ditch afterwards! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #689478 27th Feb 2018 11:54pm
zsd-puma
a cheap tarpaulin stuffed in with the jack is good to lay on. Or better still an old vinyl advertising banner.
A sprinter jack or one of the original Land Rover hydraulic ones is definitely the way to go. Both have a good saddle on them designed for axles.
Post #689490 28th Feb 2018 2:36am
The spiral wind-up Defender jack is a magnificent tool with many uses, and every Defender owner should have one. Until you have actually used one, you simply cannot begin even to imagine how good it is. As long as you don't want to jack up your Defender, its uses are limited only by your imagination.
I have one which is complete, surplus to requirements, and which has seen very little use, which I would gladly pass on to any forum member for a very modest sum! Rolling with laughter
Post #689513 28th Feb 2018 9:00am
rockster57
If it has the soft A Bar extension piece, I’ll happily have it off you Blackwolf . Seriously Thumbs Up
Post #689526 28th Feb 2018 9:54am
I dunno about the "soft A bar extension piece", what does one look like? Sadly I suspect that it doesn't, even though it was with my Defender when I bought it and the Defender did also have a soft A bar (now long since sold).
UPDATE - I've just seen your post from 4 years ago here, I presume that this the doohicky you're still looking for. In which case I will see if my jack has one.
Post #689561 28th Feb 2018 11:35am
rockster57
Thank you Blackwolf. The additional extension is the shaded component. If you have it, rather than split your jack, I’d take the whole thing Thumbs Up
Post #689567 28th Feb 2018 11:58am
Mo Murphy
You certainly don't need a high lift jack to change a tyre, so don't even contemplate the expenditure.
I'd only consider buying one now if I regularly drove in remote areas as Stephen does.
50 Shades of Pennine Grey
Post #689613 28th Feb 2018 2:36pm
A Hi Lift is nice to have, but not a requirement and the bottle jack is generally safer.
The Hi Lift is just useful to have depending on situation. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689618 28th Feb 2018 2:50pm
Mo Murphy
I beg to differ Steve, jacking the back or front of a defender on a Hi lift jack until the axle is hanging on the shock absorber with spring dislocated is NEVER safer than using a bottle jack. The usefulness of a Hi Lift jack to the everyday 90 or 110 owner is a myth and is far more dangerous than safe in untrained hands.
Just saying 😊
Post #689638 28th Feb 2018 3:29pm
Page 1 of 3 123>
