![]() | Home > Puma (Tdci) > Reverse gear switch wire required |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge http://www.brit-car.co.uk/product.php/3952...ll_models_ plug but not pins give Paul mac call Phone:07806 381223 Email:lr_connectors@btinternet.com |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
or a length of wiring harness from a scrap transit would do it I expect.
daftlad Member Since: 21 Feb 2018 Location: Notts,south yorks border Posts: 10 ![]() ![]() ![]() |
Cheers all The wire in the photo does it go into the main loom on the opposite side That were I've found a dangling 2 pin female I think |
one wire from switch go to fuse under your dash and the other wire go to the back and Reverse light
Thanks bud
Think I will extend the cut wires and plug them in to the plug I've found ,see if it works As you say back to the Fuse box and to the light so must travel down the loom somewhere |
