Home > Puma (Tdci) > Reverse gear switch wire required
daftlad
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Evening all
Seems the electrical connector that goes from the back of the gearbox switch to the loom is cut in two and I needs a new one
I've searched the usual places and can only find the switch and not wiring
Traced it back today after the reverse lamp stopped working
Can these be bought
If not can I buy the male connection or both and I will make my own
Phil
Post #688822 25th Feb 2018 7:04pm
dorsetsmith
http://www.brit-car.co.uk/product.php/3952...ll_models_
plug but not pins
give Paul mac call
Phone:07806 381223
Email:lr_connectors@btinternet.com
Post #688854 25th Feb 2018 8:57pm
zsd-puma
or a length of wiring harness from a scrap transit would do it I expect.
Post #688929 25th Feb 2018 11:22pm
daftlad
plug but not pins
give Paul mac call
Phone:07806 381223
Cheers all
The wire in the photo does it go into the main loom on the opposite side
That were I've found a dangling 2 pin female I think
Post #689065 26th Feb 2018 7:21pm
dorsetsmith
one wire from switch go to fuse under your dash and the other wire go to the back and Reverse light
Post #689090 26th Feb 2018 8:16pm
daftlad
Thanks bud
Think I will extend the cut wires and plug them in to the plug I've found ,see if it works
As you say back to the Fuse box and to the light so must travel down the loom somewhere
Post #689106 26th Feb 2018 9:12pm
