![]() | Home > Maintenance & Modifications > sqeeks and sqeals |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
I'm sure we'll have all experienced it.
I've always referred to it as a dry timing belt but I suspect it's the ancillary belt (the rubber one that does the a/c compressor among other things. you know when you first start the engine you get a squeal etc. I've tended to pop the bonnet and give it all a liberal spray of WD40 but suspect there might be other / better advise out there? ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
You're disguising a bearing failure on a pulley..... QRZ 2e0vpf
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
A new belt from Land Rover is only about Β£25.
If they've been contaminated they can polish up on the backs and slip a bit. They're supposed to be good for 10 years, but it might even have stretched a bit. Personally I'd order a new one, and whip the old one off, while it's off spin the pulleys by hand and check they're all quiet. If you've been adding WD-40 on a regular basis it'll eventually not do the belt much good. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20988 ![]() ![]() |
WD 40 will make it slip more and more, it's supposed to do the exact opposite!
Change the belt over, and clean all the pulley mating faces problem should be gone. I changed my belt over at 55k, really because it was easy and very cheap. I occasionally had a squeak on start up, not any more. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 26th Feb 2018 6:49pm. Edited 1 time in total |
Exactly. Spraying WD-40 on it is just a diagnostic aid really. If you spray it on the belt and it goes quiet then you know the belt was slipping.
aha. not looked yet but I'm guessing a simple job too? Nothing needs to be held in place like a timing belt right? ![]() |
No, pretty simple just the tensioner needs slackening off.
No need to remove fan or anything like that. Obviously isolate the battery first. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
There's a sticky in the TDCI section about it.
http://www.defender2.net/forum/topic47382.html It's easier with the fan removed, but if you don't have the tool to remove the fan you can do it with it in situ. |
