Home > Tdi > 300 or HS 2.8
Page 2 of 2 <12
L110CDL
Thanks for the info Timo K Very Happy i didn't know that M & D have stopped listing them Rolling Eyes
Mash thanks for info on the 2.8 Thumbs Up Clayton.
Keeper.
Post #686440 13th Feb 2018 10:00pm
jst
i know of a 2.8 available if thats what you decide on Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686443 13th Feb 2018 10:06pm
L110CDL
^^^ Many thanks JST i will take you up on that once i know which way i will go Thumbs Up
Is it up for sale publicly or a private sale ? many thanks again Very Happy Clayton.
Keeper.
Post #686472 13th Feb 2018 11:11pm
jst
as far as i am aware its not advertised. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686641 14th Feb 2018 9:38pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
This popped up in my random searches on eBay,
https://rover.ebay.com/rover/0/0/0?mpre=ht...3068423187
Nothing to do with me, wouldn’t be selling if it was Whistle 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #686662 14th Feb 2018 11:17pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
We put a 2.8 into this almost 10 years ago now and when I was back in Oz in Nov drove it again, it pulled amazingly, probably better than my 05 90. Put good Disco brake server in to stop it, and good radiator. And Disco gear ratios. Given all that, it'll go forever. It did drive, or say on the water gauge, that it was hot for the first few thousand km, then it settled down and pulls like the proverbial. Great engine. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #693238 14th Mar 2018 12:32pm
jst
i run Disco servos too on off roaders, and autos on Defenders, they are much better for repeated heavy braking over the std tdi ones. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #693361 14th Mar 2018 8:51pm
How easy is it to fit a disco brake servo? do you change the master cylinder as well?
Post #693823 16th Mar 2018 8:05pm
jst
Hi Jamie, its simple to change from a nut and bot job, just fiddly doing the clevis pin on the brake pedal.
on my '84 the master cylinder fitted to the Disco Servo, on my '92 it didint and i used both disco servo and m/cylinder
bearmach do a replacement servo that is std part number for defender but is actually a fair bit deeper that takes the std def m/cylinder. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #693968 17th Mar 2018 10:17am
Thanks James
Is that a disco1 or 2 servo?
Post #694113 17th Mar 2018 7:40pm
jst
disco 1, 300tdi with ABS Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #694475 18th Mar 2018 8:31pm
grafty99
Is there any advantage to fitting one to a Td5 defender? I assume there is more servo assistance? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #695132 21st Mar 2018 8:51am
jst
dont know specifically on a td5 as never done it.
there is no greater assistance just more air (well less - greater vacuum) held in the largr res which means you have servo assistance for a great period. not normally needed on a non ABS vehicle but i was running an auto and off road you use the brakes a fair bit on very steep descents, cadence breaking eats servo power so the greater the vacuum capacity of the servo the better. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #695492 22nd Mar 2018 8:44pm
grafty99
Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #695507 22nd Mar 2018 9:32pm
Page 2 of 2 <12
