Home > Td5 > Replaced entire braking system - 3 amigos remain! |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2063 |
Are the ABS sensors fully seated? Same thing happened to me a couple times ABS sensor had come loose, only took a couple mm for it to throw a fit
13th Feb 2018 7:14pm |
jrharte Member Since: 08 May 2016 Location: Newry Posts: 20 |
ABS has been removed and replaced with non-ABS braking. |
13th Feb 2018 7:27pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
In that case you need to replace the warning light cluster, there are two types. ABS and non ABS. Otherwise remove the leds from the pcb to solve the problem.
I think all non ABS defenders show an ABS fault but it doesn't trigger a MIL It's a bit late now but removing the ABS and hence traction control seems like a rather large backwards step to me 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Feb 2018 7:45pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
Instruments are the same. You need to look at the wiring diagram for the instruments and modify the wiring for the non abs model. From memory it means linking two wires back to the instruments (through built in resistors) rather than to the abs unit.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
13th Feb 2018 7:55pm |
In that case pull the fuse. Doesnt seem wise to me, could cause issues at MOT time.
13th Feb 2018 7:59pm |
It needed the modulator replaced (at a hefty sum of around £2000 for the new part). I did the galv chassis and new clutch etc last year, so no way I'm spending another £2000 plus on ABS lol. Parts and labour for the new non-ABS was £500. |
13th Feb 2018 8:14pm |
Fair enough, but you don't necessarily need to buy new. Good second hand is about £150. As it's now done however I guess there is less to go wrong 2002 90 Td5 Station Wagon
13th Feb 2018 8:20pm |
Just found this online: Click image to enlarge Click image to enlarge Is this the type of thing you mean? Connecting the wires from two pins to turn off the light? |
13th Feb 2018 8:27pm |
Dont see the issue, ABS was optional fit. Removal of ABS and fitment of all tge required non ABS parts will cause no issues. What possible issue would that cause at MOT time? 02' 110 TD5 Double Cab Rebuild Thread
13th Feb 2018 8:29pm |
Yes that's the one, see here:
https://www.google.co.uk/url?sa=t&sour...mYN0ny-K-2 Page 79 Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
13th Feb 2018 8:30pm |
Yeah no issues with MOT, if it isn't there that can't test it 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Feb 2018 8:32pm |
The brake warning light is staying illuminated as well, not just ABS and TC. I thought they would fail on the brake light being on? |
13th Feb 2018 8:36pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
looks like you need a few wiring mods; no resistors
www.retroanaconda.com/landrover/2009/10/in...tdi300tdi/ Shows some nice pin outs with colours. (may vary on earlier models, but you can normally work out the pin numbers from the back. Small plug is the 16 pin reference. Pin 10 link to pin 6 will switch off the ABS light Same plug link Pin 13 to pin 9 to switch off brake light fault. Then take same plug pin 14 and connect to break level switch (its driven by connecting to ground); also comes on with handbrake switch. https://www.ebay.co.uk/itm/DEFENDER-TD5-In...5HS5kveUPA spare plugs and pins |
13th Feb 2018 10:37pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I had once a problem with warning lights and with me it was a damaged part off the plate.
Click image to enlarge I solved it this way: Click image to enlarge A new part was expensive. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
14th Feb 2018 10:20am |
