Home > Maintenance & Modifications > Rear (felt) window seal problem - window wont close!
Kez
Isle Of Man
Made the mistake of leaving 12 year old sprog in alone in car for 2 mins, cam back to find had had pulled the back window bas as far as it would go, then he tried to close it and somehow has managed to squish up the felt that lines the window channel up into one end - needless to say window now wont close.
Have tried putting it back but as soon as I push forward the window it does the same again. Leaving it pit makes the window rattle like mad -as a temporary solution i have cut felt in half and just lined the end section - now closes and 'most' of the rattelmh has stopped but clearly its less than ideal. Does anyone know where I can get a replacement felt seal and more importantly, how does it fit - any advice most welcome.
Post #68295 22nd Apr 2011 8:43am
Kez
Isle Of Man
85 people have looked at the post, but no one appears to have an answer Sad
Post #68560 25th Apr 2011 9:52am
mse
A picture speaks a thousand words Wink Mike
Post #68561 25th Apr 2011 9:59am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
had this happen when still in warrenty, so no help there as it just got sorted,
this is what i will be using once mine needs doing again.
http://www.ekmpowershop18.com/ekmps/shops/...l-14-c.asp
HTH
mark
Post #68569 25th Apr 2011 10:47am
Merlin
I couldn't get mine back in, so I cut it off and just pushed the window closed so it doesn't show. I know it's not a proper solution but there you are.
Merlin
Post #68605 25th Apr 2011 9:02pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
It would seem you cannot replace felt seal on it's own. See here:
http://forum.landrovernet.com/showthread.p...indow-seal
Post #68612 25th Apr 2011 9:30pm
double cab happy
the fact that my stealership managed to do it in less than a week and on the first try tells me that, not only can it be done but that its a job a five year old loaded up on sugar and wearing mitterns could do it.
seriously its the only job they got right first time. Evil or Very Mad
Post #68616 25th Apr 2011 10:07pm
mse
The felt seals in all the windows can be replaced - i only know that as i have built up several defenders and refitted them to the doors and the sliding windows.
I know my dealer told me they couldnt replace it - but they could and did, when i reminded them of the heritage (for me it was to fix a rear window rattle)
Just to add - they were screwed in...then i think they were glued in on the latter versions. Mike
Post #68643 26th Apr 2011 9:25am
Kez
Isle Of Man
I opted for Merlin's solution - job done (or now anyhow!) Smile
Post #68679 26th Apr 2011 5:23pm
ogb
Apologies for the late response, but I've only just joined the forum...
I replaced my seals with window channel strip from Woolies Trim. The old stuff was always soggy, green with algae and generally tatty. It was a simple job to pull it all out having lifted the window out. Doing this job brought home the fact that these windows are about as secure as an Icelandic bank. I'll be doing something about that before I go anywhere near "civilisation".
Post #92760 5th Oct 2011 10:48am
Kez
Isle Of Man
You can lift the windows out Shocked
Post #93099 7th Oct 2011 10:18am
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
Buy the replacement trim from Woolies Trim. Easy job to replace the felt. THERE IS NO NEED TO REMOVE OR REPLACE THE WINDOWS!
Post #93197 7th Oct 2011 9:17pm
