![]() | Home > Maintenance & Modifications > Rear (felt) window seal problem - window wont close! |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 ![]() ![]() |
Made the mistake of leaving 12 year old sprog in alone in car for 2 mins, cam back to find had had pulled the back window bas as far as it would go, then he tried to close it and somehow has managed to squish up the felt that lines the window channel up into one end - needless to say window now wont close.
Have tried putting it back but as soon as I push forward the window it does the same again. Leaving it pit makes the window rattle like mad -as a temporary solution i have cut felt in half and just lined the end section - now closes and 'most' of the rattelmh has stopped but clearly its less than ideal. Does anyone know where I can get a replacement felt seal and more importantly, how does it fit - any advice most welcome. |
85 people have looked at the post, but no one appears to have an answer
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
A picture speaks a thousand words
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
had this happen when still in warrenty, so no help there as it just got sorted,
this is what i will be using once mine needs doing again. http://www.ekmpowershop18.com/ekmps/shops/...l-14-c.asp HTH mark |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
I couldn't get mine back in, so I cut it off and just pushed the window closed so it doesn't show. I know it's not a proper solution but there you are.
Merlin |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
It would seem you cannot replace felt seal on it's own. See here:
http://forum.landrovernet.com/showthread.p...indow-seal |
the fact that my stealership managed to do it in less than a week and on the first try tells me that, not only can it be done but that its a job a five year old loaded up on sugar and wearing mitterns could do it. seriously its the only job they got right first time. ![]() |
I opted for Merlin's solution - job done (or now anyhow!)
ogb Member Since: 04 Oct 2011 Location: Moray Posts: 2 ![]() ![]() |
Apologies for the late response, but I've only just joined the forum...
I replaced my seals with window channel strip from Woolies Trim. The old stuff was always soggy, green with algae and generally tatty. It was a simple job to pull it all out having lifted the window out. Doing this job brought home the fact that these windows are about as secure as an Icelandic bank. I'll be doing something about that before I go anywhere near "civilisation". |
You can lift the windows out
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
Buy the replacement trim from Woolies Trim. Easy job to replace the felt. THERE IS NO NEED TO REMOVE OR REPLACE THE WINDOWS!
