Home > Technical > Best glue for Puma dashboard?
Paul K
United States 1985 Defender 90 V8 Petrol SW Auto Portofino Red
All:
What’s the best glue/epoxy/cement to use on a Puma dash? The bit that runs across the middle of the dash at the very bottom below the heater controls is snapped off one one end. I tried epoxy but it didn’t hold. I’m considering building a bracket to help support it but I want to glue it too. What brand of glue works?
It seems this is a weak point in the design. Has anyone come up with a different fix?
Thanks,
Paul.
Post #685548 10th Feb 2018 4:11pm
Balvaig
I had a split in the rear door card which might be similar plastic. I used Araldite with a plastic support piece across the split. Held for the 18 months I had it after the repair.
Post #685552 10th Feb 2018 4:27pm
Paul K
Thanks! Looking on eBay (since nobody sells it here in the USA) there are several different types of Araldite. Which one was it?
Post #685554 10th Feb 2018 4:41pm
Balvaig
Hi sorry, didn't look where you are based.
Its Araldite two part epoxy.
Two versions here, rapid -which sets in 5mins, hard in an hour or normal -which sets in an hour and hard in 8 hours.
I used the rapid.
Post #685558 10th Feb 2018 5:15pm
ibexman
Cyanoacrylate ie superglue Thumbs Up
Post #685560 10th Feb 2018 5:24pm
Paul K
Thanks! Just ordered some.
I used the rapid.
Post #685569 10th Feb 2018 5:59pm
