![]() | Home > Technical > Best glue for Puma dashboard? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
I had a split in the rear door card which might be similar plastic. I used Araldite with a plastic support piece across the split. Held for the 18 months I had it after the repair.
Paul K Member Since: 01 Dec 2013 Location: St. Thomas, U.S. Virgin Islands Posts: 63 ![]() ![]() ![]() |
Thanks! Looking on eBay (since nobody sells it here in the USA) there are several different types of Araldite. Which one was it?
Hi sorry, didn't look where you are based.
Its Araldite two part epoxy. Two versions here, rapid -which sets in 5mins, hard in an hour or normal -which sets in an hour and hard in 8 hours. I used the rapid. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Cyanoacrylate ie superglue
Thanks! Just ordered some.
