![]() | Home > Technical > Oil Cooler & slickshift for R380 |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
Sounds like a great solution Dave.
If you need any testers, I'd happily fit one ![]() |
Thing s you should consider as:
1. When you change the oil can you drain all the old oil from the cooler and pipework? 2. What’s the new oil volume so you don’t over or under fill the gearbox? 3. Can you install an valve or bypass so you only run through the cooler on longer runs, or in the summer? You could get very technical and have a temurature controller valve that only opens up to the cooler when required. But that adds complexity and weak points when overlanding. Russell 2011MY 110 XS USW Black |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 ![]() ![]() |
hi
volume/amount of oil = i was hoping to keep the pipework below the filler plug. so oil stays in the system and gearbox at all time? Draining the cooler lines would be tricky but perhaps fitting the cooler upside down and just unclipping one port?? as for block to divert oil in and out .. hm did not think of installing one but a good point.. problem is are these hard to get? thanks joe |
Manual ball valves are easy to get hold of, you can have the the same size and thread as the connections on the cooler. Russell
hi yes i was thinking about it. wondering if it is possible to find something thermostatically operated like the 200tdi filter housing as fitted in my 2.25 diesel. but i guess a manual valve inside the cab would still be ok. or at least on the inside of chassis since i am not into the idea of butchering panels.
thanks for the insight indeed. i might do away with the steel pipe to the front and just fit the 10 row cooler under the box on the cross member. at best i can fit a small fan to it Regards joe |
If i install a thermostat housing for the R380 the pressure to the oil cooler will not be constant so fitting an oil pressure sensor will only work when the stat is open and oils flowing.
still some more thinkering before i start sourcing bits. ![]() |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
I use redline for my R380 brilliant
The bigger sump won’t fit Td5 it fouls on exhaust unless you fit upside down ![]() |
