Home > Maintenance & Modifications > Td5 Self Service
Page 1 of 3 123>
Djcla
Td5 Self Service
Hi
Thinking of doing my own service this year mainly because I want to ensure its done right with OEM parts and decent oils. Anyway if I wanted to change all the fluids (engine, axle, transfer case etc) any ideas what I'd need and quantity's etc to do everything?
Post #684624 6th Feb 2018 9:51pm
bankz5152
Engine 7.2L 5w/30 Semi Synth - Fully synth tends to cause some TD5s to leak oil.
Only really need to be done every 2 years unless you do alot of towing/high mileage/off roading
Gearbox about 3L MTF95 - fill till it comes out
TX Box about 3L EP90 or EP80w/90 - fill till it comes out
Diffs 1.7L each EP90 or EP80w/90
Proper EP90 is better than the 80/90 stuff but halfords/motorfactors dont often stock it.
Air filter
Fuel filter - I change mine every 2 years, look up the purge process if you change this.
Centrafugal oil filter - DO NOT over tighten the bolts
Main oil filter - can be a pig to change as access isnt fantastic
Buy quality filters not cheap crap, ideally genuine oil filters
Buy an oil pump (bout £15) itll make the job much faster and easier.
Always remove the fill plug BEFORE the drain plug
Post #684717 7th Feb 2018 9:17am
excossack
Interesting comment on fully synth oil causing leaks.... 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #684734 7th Feb 2018 10:50am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I filled my t box up with 75w90 as per Ashcrofts recommendation, just to throw a spanner in the works
Post #684743 7th Feb 2018 11:11am
srod
Yes, Castrol Syntrax 75W90 in the transfer box on mine.
80/90 in the diffs
Post #684744 7th Feb 2018 11:15am
rallysteve
Any evidence or basis to support your comment of fully synthetic oil causing leaks?
Post #684748 7th Feb 2018 11:34am
bankz5152
My old 90 had a weep when I used fully synth, 2 mates with TD5s experienced the same. No idea why but swapped back to semi and no weep no leak.
Post #684751 7th Feb 2018 11:48am
excossack
Maybe worth a try I guess, I use Fuchs Titan XTR fully synth and I do have a few weeps. Mainly front cam seal, rear half moon 1999 Defender TD5 110
Regards
John M0VAZ
Post #684752 7th Feb 2018 12:04pm
rallysteve
Not arguing with your experience but seeing as semi-synth is a mixture of fully synthetic oil and mineral oil then the only way I can see that leaks wouldnt occur with semi synth is if the mineral oil content causes gaskets/seals to swell or soften. 02' 110 TD5 Double Cab Rebuild Thread
Post #684755 7th Feb 2018 12:21pm
bankz5152
That was my guess too.
Post #684764 7th Feb 2018 1:57pm
Crossfit_Pete
United Kingdom 2007 Defender 90 Puma 2.4 CSW Firenze Red
Will be doing mine when the parts arrive, there are some good guides on YouTube.
Post #684783 7th Feb 2018 5:05pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Bought a cheap 5 litre pressurised sprayer (about £10) , take off the end spray nozzle and use this to fill up axle, gearbox etc oils. Works a treat.
good luck with it, I have done mine for last 4 years including coolant and belt.
Once you have done it, book yourself some flights as you will probably have saved the money in labour costs Very Happy
Post #684790 7th Feb 2018 5:42pm
rallysteve
If you use genuine oil filter I can recommend the filter spanner from paddocks etc as it makes removal a lot easier. Sadly doesn't fit all aftermarket filters.
Post #684791 7th Feb 2018 5:46pm
LandymanStefan
The Genuine oil filter is the same as a Mann filter. My last genuine filter said Land Rover and Mann on it, been with Mann ever since
Post #684793 7th Feb 2018 5:48pm
Crossfit_Pete
What service kit to people recommend?
Post #684812 7th Feb 2018 7:58pm
Page 1 of 3 123>
