Home > Maintenance & Modifications > Td5 Self Service
Page 3 of 3 <123
bankz5152
Nope none on the diffs. Just engine/sumo and gearbox.
Sump
eBay Item No. 112435773683
GB washer
eBay Item No. 323050045997
If you are draining the diffs its worth fitting magnetic drain plugs. Not essential but a good idea
Post #684953 8th Feb 2018 9:29am
Crossfit_Pete
United Kingdom 2007 Defender 90 Puma 2.4 CSW Firenze Red
Thank you1
Post #684958 8th Feb 2018 9:54am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Good source or make of magnetic drain plugs for the diffs? Will be doing mine soon.
Post #684963 8th Feb 2018 10:49am
Harry.O
The last couple I bought were eBay/Britpart specials, no complaints and unlike most things from Britpart, they don't leak. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #684967 8th Feb 2018 10:56am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Are they not the same on a disco2? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #684972 8th Feb 2018 11:30am
bankz5152
Disco2 diffs are the same.
The xcess 4x4 mag plugs are fantastic but the Britpart ones are good enough!
Post #684977 8th Feb 2018 11:53am
Djcla
bankz5152 wrote:
Ahhh forgot about the crush washers!
Theres one on the engine/sump drain plug and one on the gearbox drain plug. You also need 22 or 32mm spanner i forget which. 1/2" ratchet/drive for the diffs and a largeish (cant remember the exact size) torx bit bit for the TX box. Make sure the torx bit fully seats in the hole.
so you replace the crush washers? Is thee any special torque setting needed for any of the nuts or just do um tight?
Post #685015 8th Feb 2018 3:01pm
srod
When refilling the diffs, whatever you do, don't do what I did. I attempted to refill it using a funnel, with a short (2") piece of garden hose on the end, such the the funnel could be held upright, with the hose making the 90deg bend into the vertical refill hole. Yes, the piece of hose fell off and into the diff!!!!! A couple of hours with my fingers in both holes Shocked and eventually I got it out. Was a happy moment. Was on the verge of opening the diff to get it out with whatever can of worms that would have been, also considered just leaving it in there and driving it around and letting the gears mash it up. Was a right pain, I could get hold of it by either end with one finger in the fill hole and one in the drain, but couldn't do anything with it, kept losing it, was in total despair! Eventually managed to thread a bit of wire through the center of it and wiggle out. Just as I got the job finished a mate rocked up to help, and kindly said "oh you should have asked, I have an oil pump you could have borrowed"
Post #685022 8th Feb 2018 3:36pm
srod
Yes, always a new copper washer. Not so tight on the engine sump plug, it's going into alu... infact the torque setting is lower than what my wrench goes down to, it just feels wrong when you consider what is at stake!
Post #685027 8th Feb 2018 3:48pm
Clive
I got one of these last time they were on offer -
https://www.lidl.co.uk/en/Non-Food-Offers.htm?articleId=10632
Great for filling the axles and transfer box, just need to make sure the thicker pipe is used on the outlet side and shortened to get the pump fairly close to the axle.
I've not tried it for sucking old engine oil out as I prefer to drain it normally, engine nice and hot then front wheels on ramps to get better clearance but also to tip the sump backwards to get every last drop out.
Post #685033 8th Feb 2018 4:05pm
LandymanStefan
What brand mtf 94 does everyone buy and where from. Seems pretty dear everywhere and they're all makes I've never heard of... Only normal one I've found is carlube. £8.99/L
Post #686333 13th Feb 2018 2:41pm
Djcla
Finally getting round to this any recommendations on engine oil ? Semi synthetic 5w30 right?
Post #737283 28th Oct 2018 8:03pm
Page 3 of 3 <123
