![]() | Home > Maintenance & Modifications > Which sound proofing? |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
Thanks for info , btw any tips putting that carpet down , where did you make the joins/cuts?
The best tip is to grow another pair of arms ![]() I did it in sections: a carefully measured piece for each wheelbox, another for each side below the capping, one for the floor and one for the bulkhead. The carpet itself is stretchy and so reasonably forgiving but the glue, once it sticks, doesn't want to let go so there's little chance for repositioning. I used a wallpaper edging roller to smooth it down (and the various sound proofing layers). Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The sound insulation stuff is quite waterproof but not very robust. Rubber matting over the top would work though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Did you hide the joins easily enough? |
Yes, the picture I posted gives a pretty good indication. Darren
Yeah was impressed on the pic as I couldn't see any
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2680 ![]() ![]() ![]() |
I have a combo of Dynamat (for instance on the rear walls of my USW) and NoiseKiller (under carpet).
Very happy - can hold a conversation (or use my hands-free) at 65mph - could not do that before I lashed-out on the soundproofing ![]() Basically a full noisekiller kit plus dynamat on extra areas... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20973 ![]() ![]() |
I don't think you can beat the Dynamat but everyone has their own preferences.
There was some talk about some cheapo stuff off of eBay containing higher levels of lead and other nastys. But, it's difficult to say if that's just manufacturer spin to try and beat down rivals or true unless anyone wants to test it. ![]() I have doors and roof to do, doing the seatboxes, front floors made a big difference and the seatbox bases also. Full coverage, with maximum effect. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 15th May 2019 9:27pm. Edited 1 time in total |
Orchard Member Since: 07 May 2015 Location: Usually walking the dog Posts: 258 ![]() |
![]() 1998 TD5 CSW |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
I'm hoping to fit some of the silent coat I have very soon. Is it a problem fitting in such cold weather? Was thinking about bringing an electric fan heater in the car with me while I do it to try and get it to room temp
Warmer is better, a hairdryer is useful too during actual installation.
If you can get hold of one of course. ![]() Also don't forget gloves, it cuts very easily. Those horrible cuts like paper cuts you wouldn't even know are done until they sting. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Well I've started my sound proofing venture, starting with the bulkhead behind the seats which my sub is mounted too and makes the worst rattling noise. Used 5mm silentcoat for the bottom of the panel which was the rattliest and where the is mounted on to and the 3mm black silentcoat for the top half.
The end result is I can have my sub on full volume and not rattles any more! Amazing difference! Next venture will be the front footwells with some of the 5mm stuff to cut down the engine noise hopefully. Think I'll use the rest of the 3mm for rear wheel arches and roof lining where you don't need something quite as heavy. ![]() Click image to enlarge Will keep you posted next time I get round to doing some. π |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Think Iβm going to have a go with the Silentcoat what do you use to prep the paint before glueing it down.
I use Upol System 20 fast panel wipe, but you need respirator gloves etc and in goof ventilation such as outside.
It will clean the panel spotlessly and safe on the paint, just make sure the microfibre cloth you use stays clean and never picks up and debris like swarf etc. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 15th May 2019 9:28pm. Edited 1 time in total |
