![]() | Home > In Car Electronics > Battery light |
JonJop Member Since: 23 Jan 2018 Location: St Agnes Posts: 63 ![]() ![]() ![]() |
Thabks for this - makes complete sense - some more investigative work is needed it seems...
The main thing is that it seems as though it’s charging. I’ve used it around 15 times since picking it up a couple of weeks ago and I imagine, by now, it would have drained the battery completely if it wasn’t charging. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
It might be one of the diodes in the diode pack has failed but not the others. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
As a simple test you could remove the wire anyway and measure the resistance to ground, if there's anything it'll be a bit suspicious. Ed
