Home > In Car Electronics > Battery light
Page 2 of 2 <12
sako243
The battery light, certainly on older vehicles can only come on by one method. One side of the light is attached to battery positive via the ignition switch / a switched live circuit. The other goes to the alternator field windings.
The reason it comes on when you turn the ignition on is 12V is applied to one side. The other side being connected to the alternator field windings is a short to ground. Once the engine fires up the laws of magic pixie dust and magnetics comes in and it is no longer a short but is being used to power the field winding and turn mechanical energy into more electrical.
So either you have a shorted out high side switch or a dodgy alternator, or something else causing a short to ground on the low side.
If the light comes on when the engine is off then try removing the small yellow wire off the back of the alternator. If the light goes out then you've got a dodgy alternator. If it doesn't then either you have a short somewhere along that wire (chaffing?) which you could buzz out with a multimeter or your ignition switch is playing up. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #683869 3rd Feb 2018 6:38pm
JonJop
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
Thabks for this - makes complete sense - some more investigative work is needed it seems...
The main thing is that it seems as though it’s charging. I’ve used it around 15 times since picking it up a couple of weeks ago and I imagine, by now, it would have drained the battery completely if it wasn’t charging.
Post #683872 3rd Feb 2018 6:42pm
sako243
It might be one of the diodes in the diode pack has failed but not the others. Ed
Post #683873 3rd Feb 2018 6:45pm
sako243
As a simple test you could remove the wire anyway and measure the resistance to ground, if there's anything it'll be a bit suspicious. Ed
Post #683875 3rd Feb 2018 6:46pm
Page 2 of 2 <12
