Home > Maintenance & Modifications > How do I fill in these holes in a bumper. (DIY Led bumper)
Stacey007
OK so following my post on what bumper...
I had a 'spare' bumper in the garage I had forgotten about (like you do)
So I'm sanding it down with a view to cutting some light holes and spraying... Might as well have a go. As I'm sanding it theirs a a couple of spots of rust that now sanded leaves a little indent.
What do I use to fill this in? Under the end caps will be hidden so primer, spray but would rather the visible part be neat.
Post #682775 29th Jan 2018 10:34pm
Kurust, Isopon P38, sand, primer. I doubt anything else for such a small spot. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #682777 29th Jan 2018 10:41pm
Stacey007
^ Thanks there are a couple more but only small.
However I don't want to be able to see them once sprayed so thought about a filler but what filler.
Will give it a go.. nothing to lose.
Post #682779 29th Jan 2018 10:45pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Can’t you take them to a local friendly garage/Bodyshop bung them a tenner, and get them welded up?
It would be easier in the long run,
Once they are ground flush and cleaned up you wouldn’t know they were there. Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #682784 29th Jan 2018 10:54pm
mikeh501
on that second pic it looks like you havent got through the powder coat with your sanding. you will want to really cut through to metal surrounding the rust otherwise it will just creep underneath and lift the powder coat around your repair.
Post #682965 30th Jan 2018 7:54pm
grafty99
Best bet really would be to have it blasted and primed then paint it yourself Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #682986 30th Jan 2018 8:45pm
zsd-puma
scrape the paint off you'll find that rust travels quite a long way back from the hole under the paint. If you don't you'll find it just erupts again in a year.
Ideally you want to get the whole thing shot blasted, but given the price of a new pattern part bumper it's probably quicker and of a similar price to just buy a new rust free one. It depends how much you value your time.
Post #682988 30th Jan 2018 8:58pm
excossack
Blasted and then galv'd is what I did with my winch bumper 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #682997 30th Jan 2018 9:27pm
Stacey007
Thanks all the end holes are for the end caps so I will sand down further (I ran out of sanding discs)
Then rust preventor, prime and paint.
I will do the inside also
Post #683002 30th Jan 2018 9:39pm
miker
Also looks like you're using some sort of dual action sander. Personally I'd be going at that sort of rust with an angle grinder and wire wheel/nylon wheel/flap disc!
Post #683039 30th Jan 2018 11:42pm
Stacey007
miker
I was, as I had nothing else, they have arrived now so will have another go Smile
Post #683102 31st Jan 2018 11:58am
There are paint removal discs on eBay for that. Will take off powder coat too without eating into the metal. Downfall they do have though is you can’t get them into awkward areas. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #683111 31st Jan 2018 1:06pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
id have it blasted, holes welded and then powdercoated. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #683112 31st Jan 2018 1:10pm
Or just buy new, surely cost the same. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #683114 31st Jan 2018 1:30pm
grafty99
Beauty of having it blasted and coated is you can do all the modifications before hand and ensure it's properly coated so it'll last longer Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #683128 31st Jan 2018 2:55pm
