![]() | Home > Maintenance & Modifications > How do I fill in these holes in a bumper. (DIY Led bumper) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Kurust, Isopon P38, sand, primer. I doubt anything else for such a small spot. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
^ Thanks there are a couple more but only small.
However I don't want to be able to see them once sprayed so thought about a filler but what filler. Will give it a go.. nothing to lose. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Can’t you take them to a local friendly garage/Bodyshop bung them a tenner, and get them welded up?
It would be easier in the long run, Once they are ground flush and cleaned up you wouldn’t know they were there. ![]() Wanted, Forward Control Anything considered. |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
on that second pic it looks like you havent got through the powder coat with your sanding. you will want to really cut through to metal surrounding the rust otherwise it will just creep underneath and lift the powder coat around your repair.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Best bet really would be to have it blasted and primed then paint it yourself
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
scrape the paint off you'll find that rust travels quite a long way back from the hole under the paint. If you don't you'll find it just erupts again in a year.
Ideally you want to get the whole thing shot blasted, but given the price of a new pattern part bumper it's probably quicker and of a similar price to just buy a new rust free one. It depends how much you value your time. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6027 ![]() ![]() ![]() |
Blasted and then galv'd is what I did with my winch bumper 1999 Defender TD5 110
Thanks all the end holes are for the end caps so I will sand down further (I ran out of sanding discs)
Then rust preventor, prime and paint. I will do the inside also |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Also looks like you're using some sort of dual action sander. Personally I'd be going at that sort of rust with an angle grinder and wire wheel/nylon wheel/flap disc!
miker
I was, as I had nothing else, they have arrived now so will have another go ![]() |
There are paint removal discs on eBay for that. Will take off powder coat too without eating into the metal. Downfall they do have though is you can’t get them into awkward areas. ____\We|Will|Win/___
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
id have it blasted, holes welded and then powdercoated. My 90 Project : http://www.defender2.net/forum/topic52774.html
Or just buy new, surely cost the same. ____\We|Will|Win/___
Beauty of having it blasted and coated is you can do all the modifications before hand and ensure it's properly coated so it'll last longer
